Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Food particles on washed plates
Dishwasher: Hot Point Mod# HDA 200 X - 72BA
Is there a place (- not visible from the loading area -) at the bottom of the dishwasher where food particles remain and never get drained?
  • shvo Nov 18, 2007
    I would say that it is a poor design because the food particles accumulate along the entire bottom of the door and also interior bottom of the strainer (held in place with two screws) in the bottom of the dishwasher tub. Inside of the strainer was terribly filthy -- looked like mushrooms were growing. I noticed that small black sticky particles were stuck to the top of the tub as well.
    I replaced the unit with Whirpool DU series.
  • 25 Answers
Sometime food particles stick near the door gasket. First, try changing the DW soap brand.
Posted on Nov 16, 2007
I have a whirlpool gold quiet three.It has never been used I do not have the instruction manuel. help with starting please
If you've just installed a Whirlpool Gold dishwasher, consider yourself truly liberated from the drudgery of standing at the sink washing plate after plate and saucepan after saucepan. You'll find it much easier to keep the kitchen clean as your dirty dishes are hidden away in your new appliance and all you have to do is wipe down the counter tops and switch the dishwasher on when it's full. However, to get the maximum benefit from your new piece of equipment, it's important to use it correctly.
* Dishwasher detergent
* Dishwasher rinse aid
Preparation of Dishes
1 Scrape leftover food off the dishes and make sure no other hard objects such as small bones or toothpicks remain on them.
2 Remove sticky labels from any newly bought food containers you are washing for the first time.
3 Make sure any leftover coffee, tea, soda or wine has been poured out of cups, mugs and glasses.
Loading the Dishwasher
1 Place cups, mugs and glasses in the top rack with the open ends pointing downwards. Cups and mugs should go along the left and right outside edges, with glasses beside them. Position small plates and saucers in holders along the center of the rack running from back to front.
2 Place larger plates and bowls in the bottom rack, which is also where casserole dishes and saucepans should be washed. Avoid overlapping bowls and plates, because it is important every surface is open to the water directed around the dishwasher's interior during the program.
3 Create a flat surface on which to lay saucepans and larger dishes by collapsing some of the plate holders on the bottom rack, if your model dishwasher allows. Lay them open-end down to allow the water to be directed around their interiors.
4 Position dirty saucepans at the rear of the bottom rack with the open end facing the back of the machine's interior, if your machine has a "PowerScour" facility.
5 Place silverware in the silverware basket with sharp items pointing downwards. Alternate the direction in which you load spoons to prevent them "nesting" together, which stops water reaching every surface.
Detergent and Rinse Aid
* 1
Place detergent in the dispenser just when you intend to run the wash cycle, not before. If you're using standard powder or liquid detergent, be guided by the hard-water and soft-water indicators. These are lines marked in the side of the dispenser. In areas with soft water, fill to the soft water line and in hard-water areas fill to the hard water line. If you prefer individual tablets, follow the manufacturer's instructions.
2 Add rinse aid immediately when the rinse aid indicator reaches the "add" level. Turn the cap on the rinse aid dispenser to "refill" and lift it away from the dishwasher. Pour rinse aid into the opening until the indicator reaches the "full" mark and replace the lid. Make sure the lid is tightly in place.
3 Adjust to a higher setting on the arrow adjuster, located inside the dispenser, if you feel more rinse aid is needed during a wash cycle. You can do this by inserting a flat-blade screwdriver into the center of the adjuster.
Starting the Wash
* 1 Check that the spray arms can rotate freely before closing up the dishwasher.
2 Turn on the hot faucet at the sink closest to the dishwasher and let the water run until it is hot.
3 Close the door firmly and select the wash cycle you wish to use. Depending on which model you are using, you may wish to activate additional options during the cycle such as "Power Scour." These options should also be selected at this stage.
Nov 03, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Our dishwasher is only 4 months old. Sometimes there will be small particles of food left on some of the plates. Also when we wash glasses in this machine they are cloudy or dirty looking.
There are several reasons that the food can be left on the plates. If the washer filter is plugged (partially) then the food particles can remain in the tub and be re-deposited. This can also happen with a dirty sump. According to the specs, your filter is self cleaning, and has a food disposer. The link to your machine is here:
I think, in your case, a good cleaning would help. When the disposer isn't working well, the screen can be coated, and needs to be cleaned to be efficient. Your manual, accessible from the link above, (then select specifications, scroll down to another link) recommends a vinegar wash and is described there.
For heavy duty cleaning, you can (in this order): Add 1/2 cup of salt, 1 cup of baking soda, and 2 cups of vinegar. Spread the ingredients around the screen, one at a time, at the bottom of the tub. It will begin to foam. When it has quit foaming, add 2 cups of bleach, and run a hot cycle (Pre-heat the water by running the hot water faucet closest to the dishwasher until hot).
Best regards, --W/D--
Feb 12, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
When my Kenmore 665 dishwasher is done with the cycle, the glasses on the outer areas of the top rack have stuff stuck to them. Almost like the jet spray is clogged and spraying the garbage. My...
I do believe most manufacturers recommend emptying the strainer after each wash (much like you would a lint filter on a clothes dryer). With the door open, look inside on the bottom. You should see a plastic cylinder shape about 2-3" in diameter. Twist it counterclockwise and gently pull up. This traps large pieces of food, and the occasional piece of plastic wrap, toothpicks, etc. that seem to get past the kiddos when they load it. If you find large amounts of food particles, I suggest pre-rinsing pots, pans, plates before placing them in. Good luck, and please keep us informed of the progress on this concern.
Sep 21, 2017 | Kenmore 15129 Built-in Dishwasher
Dishes remain dirty, Food particles all over interior of dishwasher. hotpoint dishwasher model HDA2030Z02WW
In the back of the dishwasher at the base there is an indentation. This is where the food particals go when they are washed from the dishes. In this indentation there is a filter and a small wire appendage that is connected to the impeller of the motor. What happens is the dishwasher takes the food off the dishes and it is washed into this indentation area where the wire appendage turns breaking up the food particals to be flushed out during the drain cycle. What it souds like is this filter is clogged to the point no further waste can be flushed out. If you take the bottom tray out and reach into this indentation you will feel the filter. (note) there is a cover over this area that will need to be removed to access this filter. Once the cover is off you can reach into the area and you will feel the filter which should pull up and out. Be very carful when reaching into this area due to broken glass particles that may have accumulated. Once the filter is out clean the area well and replace the filter and you should be good to go
Hope this helped
Mar 31, 2010 | Dishwashers
IT is leaving food on the dishes
You do not have to prewash your dishes before loading them. In fact, by prewashing, you actually defeat the purpose of most dishwasher detergents. These detergents are activated by the grease and oils in food and work better. You should only scrape your plates of solid materials that are not recommended to go into a dishwasher (i.e., celery, popcorn kernels, tough chunks of meat, gristle, etc.).
If you are getting food particles on your dishes, this is known as "redeposition". Most commonly it is caused by food particles trapped in the filter of the main wash pump. You will need to remove the lower spray arm and access the filter screens and clean them of all debris.
If you need further assistance on how to disassemble your dishwasher to access the filter, please post back with your MODEL NUMBER. I hope this information is helpful to you.
Mar 29, 2010 | Dishwashers
Food particles left on dishes
Many times this caused by food particles clogging the screen or blocking the jets on the spray arms. Find the screen in the bottom of your machine and clean it out. If this doesnt help, remove the spray arms and clean them out.
Jun 17, 2009 | Dishwashers
Food particles clogging up drainage system at bottom of dishwashe
Take it apart. Clean large particles of food off before placing in unit. You might try a little Clorox and wash at hottest temperature while empty first.
May 16, 2009 | Maytag 24 in. MDB9150A Built-in Dishwasher
Food residue on all dishes
The filter systems on the Maytag line of dishwashers which includes Jenn Air is very fine. In most causes the pump needs to be torn down and washed in a sink and a shop vac is also a great tool I use to clean the rest of the pump out that will actually stay in the dishwasher. The spray arms also need to be cleaned in the sink. Check your drain line under your sink as well and make sure that the drain line coming from the dishwasher has a high arch or bend that is higher than the base of the sink. This will prevent sink water from backing up in the dishwasher which can be nasty. Also make sure to run your hot water to the sink before starting a cycle to assure hot fills and the water temp. is best if set at 130 degrees on your water heater instead of 120 or 125 degrees. I hope this is helpful. This kind of problem can be agrivating to solve at times. Scott (North Caolina)
Apr 20, 2009 | GE Nautilus 24" Built-in Dishwasher
A white nasty film on the dishes after washing
Check to make sure there are no bits or trash or paper around the bottom parts of your dishwasher. Place a bowl of vinegar on the bottom rack of your empty dishwasher. Run your dishwasher through a complete cycle.
Mar 23, 2009 | Dishwashers
Food odor builds up if dishes not washed daily, even though we rinse evrything thoroughly before loading dishwasher. No water remains at bottom - nothing appears to be stuck in drain. Any thoughts?
No matter how well you rinse wares, some food particles will always go into the machine. Sometimes these particles can build up and lead to what you describe. I would start by inpecting the wash tub area; remove screens, remove wash arms and clean as needed. You are looking for any residual food soil which would harbor bacteria. If all else fails, follow your nose!
Once everything is as clean as you can make it, then purchase a product for cleaning/deliming your machine. One I know of is called "Dishwasher Magic" which should be available at most appliance repair stores. Run this through the machine on a long or heavy cycle. Once complete, run a second cycle with nothing but water to rinse any lingering chemistry.
Lastly, for a 3rd (and final) cycle, add a cup of bleach to kill off any remaining odor-causing bacteria. But, DO NOT SKIP THE RINSE CYCLE mentioned above.
This should take care of the problem,
Aug 23, 2008 | LG LDF6810 Built-in Dishwasher
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
214 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
