Whirlpool GFG461LVS Stainless Steel Gas Range Logo
A
Anonymous Posted on Sep 12, 2015
Whirlpool gfg461lvs broiler won't light
Oven works, but broiler will not light.
Richard C Cohen
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Whirlpool Expert 318 Answers
  • Posted on Sep 12, 2015
Richard C Cohen
Whirlpool Expert
Level 2:
Legend:
Answers
318
Questions
0
Helped
120633
Points
917
Hello. How old is the range? The broiler ignitor might be worn out. The part number you might need is 8054129. The ignitor for the bake is 9758079. I hope this helps you.
  • Anonymous Sep 13, 2015
    We bought this range 4 years ago and have never used the broiler until the other day and it did not light. This may be a manufacturing defect that was never caught in final testing. I don't think the igniter is worn out because it has never been used.
  • Anonymous Sep 14, 2015
    Problem solved. One of the plugs (P2-4) on the oven control board was disconnected. This plug provides power to the broiler circuit. The front panel cover had to be replaced due to damage after delivery and this plug may have been dislodged during the replacement of the panel. Thanks for your help anyway.
Whirlpool electric range oven broiler not working
Hello. This is a common failure for this range. Replace part number
9762215, price varies but about $100 average.
Whirlpool oven won't light
check the bulb in the oven
or oven light wsitch look more to the bulb
On my whirlpool gas range only 1 burner out of 5 will ignite. oven light works, oven ignites. only 3 months old and worked fine until now.
Most often when cleaning, soapis left behind and obstructs the flow of ignition gas normally directed at the exact point of the spark. Check this area and use a small wire brush to clean these area of the burners that do nto work. Let us know if this helps. Eric Campion
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
My broiler won't work on my 2006 whirlpool range model werp3101sq serial number RT110117. The manual does not indicate where the fuses are making it difficult to troubleshoot. A direct call to the...
The igniter is the first thing that goes bad on the broilers or the oven you need the igniter, it is the part next to the burner is towards the back and it lights up first it glows that's the part that's bad which is the igniter
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
5helpful
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
2answers
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
