Question about Philips Magnavox 27MS343S 27" TV
This set has no picture on the top third of the screen plus the top edge of the picture has foldover. I tried the vertical adjustments that are accessable in the service mode but this did not help. From the posts I've seen, this is a common problem with this set but no solutions were given.
  • 100 Answers
Need replaced capacitors in vertical output..
Posted on Jul 12, 2009
Vertical foldover on bottom of 32 inch samsung lcd tv about 3 inches across bottom of screen
usually on all image related problem on all LCD comes from faulty t-con board..but for sure try to play dvd movie to test if the problem is on tv/t-con...
Jul 18, 2012 | Televison & Video
Reduced vertical width and foldover at top of screen after set warms up. Picture is about 4'' when set is cold. No attempt has been made to service.
The set has bad capacitors and an ic that needs to be replaced in order to rectify the problem, and there is a chance that bad solder joints will need to be addressed with a soldering iron.
Feb 16, 2011 | Sansui RZ-3200AV
Picture cramped a little on top and reduced half inch bottom
you need to adjust the display setting in the menu option .reduce little from top and botom
Mar 19, 2010 | Televison & Video
Folddover at top of picture about an inch from top
Replace cap. 2465 and cap. 2561. That should take care of it unless the vertical transistors are bad or there are other bad caps.
Oct 27, 2008 | Philips Magnavox 27MS343S 27" TV
Wide black area top of the screen.
More than likely it's not the crt. If the picture has "foldover" at the top of where the picture is currently, then more than likely there are bad caps. in the vertical scan circuit. If not, the vertical sizing probably just needs to be adjusted. You will have to get in to the service menu to do that.
May 26, 2008 | Philips Magnavox 27MT5405 TV
TV picture
This set will need to be serviced by a tech shop as you have a problem called "vertical foldover"...accordianman
Apr 09, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Philips magnavox 32" TS3260C1
Sounds like retrace lines. Leaky caps or worse can cause this.. Are you getting any vertical foldover at the top of the screen?
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
DS25390 Verticle foldover
If you have a picture but the top is folded over, your vertical IC is probably good and you need to replace the pump-up capacitor next to the IC. When the pump-up cap (typically a 47 or 100uF 35V cap) is open then the picture will have white lines and foldover at the top. The typical vertical output IC is the LA7838, but I am not familiar with exactly which output IC your set uses.
Jul 02, 2007 | Sanyo DS25390 TV
Half a screen
The picture on your TV screen is driven from the center to the top and bottom of the screen by the vertical drive circuit. The fact that you can see the entire picture means you have a problem called foldover. This is caused by a failure in the vertical drive circuit where the vertical saw signal is altered by a component failure within the vertical drive circuit. You cannot solve this problem but any good repair shop should be able to correct the problem at a reasonable cost.
Jun 22, 2006 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Philips Magnavox 27MS343S 27" TV Logo
91 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
