Question about RCA 32V550T 32" TV
Tv won't turn on
I tried to turn my tv on this morning and it wouldn't come on. there isn't a reset button to my knowledge.  i turned the cable off and then back on but it didn't help. can you help
tv will not power on
  • 1,694 Answers
Re: tv won't turn on
Probable bad flyback transformer = shop repair....Do you want
part # 's....? Please provide service number from back of set..
Posted on Dec 08, 2007
0 characters
3 Points
My pansonic tv model ct-13r37s won't turn on by
if their is no any power indicator at the front panel the cause is either the primary fuse at the power supply section blown. and then if the fuse is blown that was mean the regulator transistor and the horizontal out put transistor could also damaged. this case can be hand held by trained technician. if you want a do it with your own just make sure you have at least a basic knowledge in electronic repair since you are dealing with some high voltage parts a care must be needed.
Aug 12, 2012 | Standard (CRT) Televisions
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
I currently have my KV-27FS120 Sony TV connected to a cable box, which is receicing 100% signal. However, my television when powered on, the picture will tend to flash at times for a half a second and then...
Check whether the issue occurs with all the external devices like DVD Player, VCR, etc. If the issue is occurring with all the devices then the issue is with the TV.
Try these steps to check whether the issue is resolved.
1.Disconnect the power cable and connect it to a different working wall outlet.
2. Disconnect surge protector if you are using any.
3.Power reset the TV by turning it OFF for atleast one minute.
3. Reset the TV to the Factory defaults.
To reset the TV, turn it ON.
Press the RESET button on the Remote and press the POWER button on the TV at the same time. Now, TV will turn OFF and then back ON automatically.
Now, proceed with the Auto Program.
Check whether the issue is resolved after the Auto Program is finished.
All Sony TVs have a self-diagnose mechanism where the Standby light blinks to indicate that there is an internal malfunction in it.
Note: Your TV does not have the replacable LAMP.
If the issue persists TV requires service. Contact nearest Sony authorized repair center,
Jul 22, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Lost blue; otherwise normal; blinks 5x
If the TV standby light is blinking for five times then you may perform the steps given below:
(i) Turn off the TV then disconnect all the cables from the TV.
(ii) Next, reconnect all the cables after two minutes.
(iii) Please make sure that the power cable from the TV is directly connected to a functional wall outlet.
(iv) Next, you may try resetting the TV to the original factory settings.
Please follow the steps that are mentioned below to reset the TV to the original factory settings:
(a) Turn ON the TV.
(b) Press and hold the Power button on the Remote Control supplied with the TV, then press the Power button on the TV front panel.
(c) Release the Power button. The TV will turn itself off, then back ON again.
(d) Next, release the Reset button on the Remote control.
If the standby light still blinks then the issue may be with the projection lamp in the TV and requires replacement.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV won't turn on
Hi There,
Try unplugging the TV and wait 5 minutes, plug it back in. Let me know what happens.
Mar 29, 2009 | RCA Standard (CRT) Televisions
Tv won't turn on
Please verify model number and give service number.....T.
Oct 25, 2007 | RCA 32F531T 32" TV
RCA 32V420T 32" TV
reset by unplugging AC cord for few minutes, a few hours,or overnight,if needed.Let me know if that does not work.T.
Oct 09, 2007 | RCA 32V420T 32" TV
RCA 32V550T 32" TV Logo
69 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
