Question about Sport & Outdoor - Others
Yamaha 9.9 4 stroke oil indicator light(green) goes out at low
Rpm's and starts making noise. when i first crank it the light stays on but when i put it in gear the light goes off and it starts running rough. is there an oil pump on this motor?
  • 178 Answers
SOURCE: rough idle stalls at low rpm's
hello first check your idle with the car running foot on brake see were your rpm reading is if your below 500rpm check your label underhood for your curb idle setting second see if theres a adjustment screw you can increase were your gas cable lever rest against your set screw underhood if you feel confident enough remove your iac motor idle air control valve if the bore were the end of the pintle extracts out to close has varnish builup our carbon it will stick creating vacuum leak type senario causing stalling rough idle sometimes even no start conditions good luck
Posted on Sep 18, 2008
  • 67 Answers
SOURCE: Oil Pump light flickering + rough idle on 1996 Nissan Maxima
Sounds more like the Throttle Position Sensor or another sensor is letting the engine RPM's drop too low. When the RPM's are too low, the oil pump is not pumping enough oil.
Posted on Feb 26, 2009
teezay731
check your transmission fluid,the motor will stall when fluid is low
Posted on Mar 24, 2009
SOURCE: evinrude 225 fitch ram injection
Mine does the same thing and I have spend $3500 trying to fix it and I am fed up. Put in new lines, impeller, thermostats, EMM. Still does it.
Posted on Jul 18, 2009
  • 273 Answers
SOURCE: Clutch Malfunction and Adjustment
check clutch cable it could be either stretched or snapped if not you need a new clutch
Posted on Aug 12, 2009
Will a 1987 Yamaha riva razz start with oil light on while trying to start it
check the oil level.If it is a normal engine lubrication set up the it will require oil pressure to put the light out which means that as soon as it starts or during cranking the light will go out and it will start. If the oil light is an indicator of low oil level then it will not start until you put oil in the emgine . Check the switch for correct opertion.
Oct 22, 2014 | MotoBatt 1987-2001 yamaha sh50 riva razz...
1999 chrysler sebring low oil pressure at idle
It may be the oil pump. If the gauge is going up when the rpms increase it's probably not the gauge or pressure switch. If the computer senses the oil pressure is low it will shut the vehicle off to try to save it's self from catastrophic failure. Also it may start cranking longer before starting. Thats it building oil pressure before the computer will let it start. Make sure oil is full, clean & thick.
Nov 05, 2012 | 1999 Chrysler Sebring
Knocking knoise under 1500 rpm
If your car has hydraulic tappets and low low oil pressure at engine speeds then it can make tapping noises. Oil pressure is needed to maintaine the tappets clearances, excessive cleaeances will produce noises.
Jan 30, 2012 | 2000 Pontiac Sunfire
My rt 100 is blowing white smoke and barely idles, also what kind of oil goes in the oil tank and what oil goes in the crank case thanks.
I see this is for an RT vehicle -- the post indicated it was a motorcycle.
But, here's an oil recommendation for the engine ::
AMSOIL 0W-40 4-Stroke
Charlie
Jan 13, 2011 | Yamaha XT 125 X Motorcycles
Self-propelled mower started smoking and it was running kinda rough. Then, it started smoking more and more while the motor slowed more and more with the increasing amount of smoking until it died. It will...
not if is a 4 stroke engine not being bothered to include engine make , model year etc makes answering accurately.
you could even say the color of the smoke
so here is a generic answer ( 4 stroke )
it indicates that there is a problem in the needle and seat and there is no fuel flow control in the carby
if it is a 2 stroke with a carby --same problem
ordinary engine oil (20w-40) for 4 stroke sump) and special 2 stroke for 2 stroke engine
Nov 16, 2017 | Poulan Pro 22" Self Propelled High Wheel...
Yamaha 50 hp motor oil red and green oil sensor lights are on
The engine will self destruct if you continue to run it without the proper oil mixture. Some oil systems have to purged of air if ran dry. Seek professional assisstance.
Aug 21, 2009 | Bass Pro Boating
Bought car five days ago. when originally cranking rpm's would stay high and only go down once in gear. now when cranked rpm's are less than a thousand and oil light comes on and starts to run hot. while...
The grinding below your feet is the starter,the oil light will allways come on when the rpm's drop to low.
This sounds like a vacuum leak,clogge EGR, throttle position sensor,or incorrect timing.
what is the temp when you say it is overheating?
Jul 29, 2009 | Land Rover Range Rover Cars & Trucks
Wont stay running with out the choke on
it sounds like you need a carb clean performed. the idle cuciut jet is probably dirty and that is the jet that supplies gas to the combustion process at idle rpm's. when you have the choke pulled out it is adding fuel and air so when you shut off the choke the fuel supply goes away. for the oils use yamalube 2 stroke oil for pre-mix and 10w -30 gear oil for your tranny.
Dec 17, 2008 | 2003 Yamaha YZ 125
Sport & Outdoor - Others Logo
76 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
