Question about Honeywell Programmable Thermostat Heater
Thermostat installation I am installing a new thermostat for my baseboard electric heat. The electric box has 2 wires comming into it. So I have 2 black, 2 white and 2 ground. The old thermostat had a place for all 4 wires (one side line one side load) the new thermostat is a honeywell RLV430 High voltage (at least I got the high voltage part right). It only has 2 wires so I am at a loss as to what to hook up where.My inclination is to hook the load to one and the line to the other. But I don' know if this is right
  • 4 more comments
  • paul306 Nov 28, 2007
    I've purchased the RLV430 thermostat and it has two black wires. However, my old thermostat has a two separate wires that contains smaller wires (red, yellow, white, green and blue) which totals 7 small wires. Please provide your feedback.
  • Anonymous Dec 12, 2007
    YES I HAVE THE SAME PROBLEM PLEASE REPLY TO rtirrell@greenwaldindustries.com Thanks Bob
  • Anonymous Oct 10, 2008
    I to, have 4 wires. 2 black and 2 white. I tried tying the 2 blacks together and the two whites.
  • tapsman Dec 05, 2008
    I also have 2 white and two black wires that were attatched to the old thermostat, they both have power in them. When I attach them as per directions(2 whites together, 2 blacks going to the thermo) there is no power at all in the thermo. I have installed at least 3 others in the house the same way and they work fine. Can you help?
  • tucheturtle Dec 06, 2008
    I have an old Honeywell baseboard thermostat that is connected to two heaters. I am installing the RLV430. The old thermostat has 2 red wires on one side and 2 black wires on the other side. There is also a white wire. The new thermostat has only 2 black wires. The diagram in the manual is very confusing. I don't understand what those squiggly lines are on the diagram. Can someone give me a better diagram? Or explain it to me.
    Thank you
  • lisa_sch Mar 04, 2009
    The old thermostat had a place for all 4 wires (one side line one side load) the new thermostat is a honeywell RLV430a High voltage. It only has 2 wires so I am at a loss as to what to hook up where.
    Sergeant:
  • 288 Answers
On paul 306, I don't have any info on you're system, but the old thermostat that has the smaller wires with the colors you described is a low voltage (24volt) controls. The new one you purchased sounds like it is for a system that is made for line voltage (120 volts or more) connecting this to the unit may have bad results. This also may apply to GUEST.
COACOOCHEE, the white and black coming into the box is the line, even though white should not be used for line, the connections for the other side of the thermostat is the load. The new thermostat you have be a single pole break as opposed to the old one may be a double pole. You should have a meter to check the voltage coming into the box, it may be 120 or 220 depending on what you have. Without any more info I cant be sure, but you may be able to connect the black wires to the switch and the white together. But it would be wise to test with a meter to be sure before doing this.
Posted on Dec 17, 2007
How do I install a basic digital thermostat?
Posted on Feb 04, 2008
3 Suggested Answers
hardrocko
  • 1476 Answers
SOURCE: I am installing a new thermostat for my baseboard
Any thermostat for elecric heat breaks the line/load connection as you said. Your old thermostat broke both the hot and the neutral. I would recommend first that you consult the instructions with the new thermostat or go to their website at http://yourhome.honeywell.com/home/Products/Thermostats/SummaryList.htm
to use their online help. Without seeing the instructions or the thermostat I think you are probably right. I would hook one black to one, the other black to the other, and the whites (which are neutral) together. Let me know if you need more help but check the website.
hardrocko
Thanks for using FixYa
Posted on Mar 04, 2010
dorothyslaug
  • 5 Answers
SOURCE: The middle of the touchscreen of my Honeywell
it not a touch screen, its manual old style honeywell, square box, not round, not rectanglur.
Posted on Nov 03, 2013
Testimonial: "It is a touchscreen. I have seen references to the battery being round and lithium CR2450; however, not sure if this is accurate. Does anyone know?"
I am installing a new thermostat for my baseboard electric heat. The electric box has 2 wires comming into it. So I have 2 black, 2 white and 2 ground. The old thermostat had a place for all 4 wires (one...
One wire is "IN" the other is "OUT" A Thermostat works by "Breaking" the "Phase" line. It is just that simple. You usually have a pair of wires that connects, on the "Hot" side, to the always power ON line, & neutral. The Circuit, or Load, on the "Cold" side, has a a pair of contacts that open & close depending on Thermostat, in series with that conductor. Hot Contacts Cold P In-------------------><-----------------P Out
N----------------------------------------------------N
Mar 04, 2010 | Honeywell Programmable Thermostat Heater
I need a picture diagram of how to wire up two different baseboard heaters with seperate thermoststs on the same wire in the breaker box.Never done this before and I don't want to burn down my home.
it can not be done. if you want 2 seperate thermastats servicing 2 seperate baseboards, then what you will have is 2 seperate circuits, one for each thermastat and baseboard. If you are talking about only at the breaker box, then that can be done.... assuming that the total amperage does not exceed the wire rating or the breaker..... if that is the case you will have to install a junction box and split the wiring BEFORE it goes to each seperate heating unit.
Mar 02, 2009 | Fahrenheat Electric Convector Baseboard...
Disconnect baseboard heater
After confirming that the heater circuit is de-energized, simply go to whatever heater that you want to disconnect, open the junction box, remove the heater wires and cap them off. Twist the remaining circuit wires together, wire nut, replace the juction box cover and on to the next one. There are ways to install a thermostat at each heater too.
Jan 17, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
Wiring for a Honeywell RTH2310B
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
Electric baseboard heat not getting hot
Is your fuse box and main power source large enough to handle the full load if all are turned on at the same time? Are you uses two pole breakers? you might only be feeding with 110 volt. This would prevent them from getting very hot.
Jan 03, 2009 | Heating & Cooling
Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Nov 22, 2008 | Fahrenheat Electric Convector Baseboard...
Farenheat baseboard heater F2544
I just had the same problem last night. Wire the two red wires from the thermostat to the power source from the service panel. The remaining two black wires from the thermostat connect to the heater.
Oct 20, 2008 | Fahrenheat Electric Convector Baseboard...
Wiring on thermostat tl7235a1003
OK, here's my guess at this...I hope someone more knowledgable will confirm or correct me.
A line voltage thermostat switches the power to the baseboard heater. In other words, it's just like a wall light switch except it activates and deactivates based on the temperature.
I think your old model CT62 was wired exactly like a light switch. The hot wire to the light is broken then run to the wall switch and then back to the light so there's no neutral wire at a light switch box. This worked fine for your CT62 because it did not need power, it only needed to switch it.
The new model TL7235A1003 requires electrical power because it's programmable so you need both a hot wire and neutral wire at it's installed location. In addition you also need 2 wires leading to the baseboard heater so the thermostat can supply it's power.
I believe L1-L2 are to be connected to the hot/neutral wires, and the Load wires go to the baseboard heater.
If I am correct you will not be able to use this thermostat without some re-wiring.
Good luck.
Nov 27, 2007 | Ingram GMS90904CXA Heater
Heating & Cooling Logo
1,140 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
