My antennae (wireless extenders) have stopped transmitting. The LED lights are working fine, but the wireless signal suddenly stopped working...any ideas?
Throw it out/
To determine if your PC will simply not connect or if really your wireless AP/Router, please download NetStumbler,
install and run. The software will determine if there is an AP within
your immediate area (including yours/high signal strength), if there is
& it is yours, then it is configuration problem, it none or some
but weak (low signal/not yours) then it is a hardware problem and would
most probably require replacement. Most of the time, the cost/time of
repair would make the purchase of a new one more reasonable. If your
Wireless Ap/Router was detected by NetStumbler, then perhaps what you
need is to re-configure your system/set-up again.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional; information.
Good luck and kind regards.
the picture is snowy with the remote on or off
I found a radio shack wireless remote control extender in a thrift store and don't know how it works. It is a pyramid type. One has an antenna the other does not. There is a red light and a round connection on the one with the antenna. [email protected] Jerry
intermitten operation, sometimes it works and other times it will not function. it appears that it needs to set for a few minutes each time it is used.
