Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Maytag french door frig - Freezer works, frig warm
Mfd 2560 - compressor replaced oct-08, now frig not cooling, no air coming thru vents either.
    Champion:
  • 363 Answers
Sounds like the freezer fan motor is worn out
Posted on Jul 22, 2009
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Frig is warm, freezer is working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Maytag MFD2560HES Bottom Freezer French...
Frost in freezer fridge warm
Sounds like the circulating fan behind the rear panel inside the freezer section is starting to go bad, This problem is very hard to diagnose because the fan still spins but at a much lower rate than needed to circulate chilled air thru the freezer and the frig. The minimum cost for parts and labor is around $300.00.
Aug 02, 2009 | Maytag MFD2561HE Bottom Freezer French...
Frdge not getting cold
Since your unit will have only one compressor, the cooled air must be circulated via a fan that distributes the air between the two compartments and this has probably died. This allows the cooled air to simply fall downward. When you can hear the compressor running, hold your fingers in front of the vents in the refrigerator compartment to see if you can feel any air stream.
Jun 07, 2009 | Maytag MFF2557KES 25 cu. ft. French Door...
Freezer Works Frig Stays at 70
Wow, pay for the Premium Assistance Plan to get a quick solution ! I fixed my issue but thanks for the help ! I went to a FREE online forum and got my fix.
Mar 25, 2009 | Maytag MFD2561HE Stainless Steel Bottom...
No air movement in frig and does not cool or freeze
you need to get a tech to look at it it sounds like a sealed system issue Compressor,drier etc....
Nov 12, 2008 | Maytag MFD2560HES Bottom Freezer French...
Water dispenser in my Maytag french door refer has suddenly stopped working. We use it every day and the filter seems to be fine. It almost sounds like it is frozen. Please Help!!!
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
FRIG AFD2535DES FRENCH DOOR BOTTOM FREEZER
Is your freezer fan blowing when the ref. is running, should feel air coming out the vent then,,,when running.
Aug 27, 2007 | Amana AFD2535DES French Door Refrigerator
Maytag MFD2561HEQ Bottom Freezer Refrigerator - Freezer working, refrigerator not
Marc of Nc. check to make sure the fan in the freezer is operating when the compressor is on. The only thing the fresh food section gets its cool air from is the freezer. and if the fan is not operating no cold air will get up there. If the fan is running you need to make sure the air duct is not blocked with frost of the evaporator is not iced up. Check that out and get back with me if there still is a problem. Good Luck
Aug 05, 2007 | Maytag MFD2561HEQ 24.8 cu. ft. French Door...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
331 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
