Question about Mongoose Cycling
Bike shifts while riding - Mongoose Cycling
    Problem Solver:
  • 10 Answers
I cant really help you without knowing which gears are shifting. Actually take the extra five minutes and accvurately describe the problem.
Posted on Jul 12, 2009
Where can I find a manual for a Falcon adventurer bike? I haven't ridden it for a few years and can't remember how to work the gears
It means its an 18 speed bike. The shifting is easy. Start with the left side, begin riding, keep pedaling, don't stop pedaling in ther middle of a shift, it will throw the chain. As you ride, twist the shift grip, up and back. Still pedaling? Now after you have tried that one, try the other side, its the rear with 6 gears. Up and back, keep pedaling. After you have tried each individually, try them together. And now you're shifting. Looking good
. KEEP Pedaling
Sep 21, 2014 | Cycling
How to use 3 gear bike ?
Thre speeds are great bikes, they last forever and are great for urban riding. These shift opposite of derailleur bike. They shift while coasting. You coast (stop pedaling) shift and then reengage
Aug 12, 2014 | Cycling
1992 ktm 300 dirt bike is stuck in neutral and will not shift
sounds like you may have bent a selector fork. need to pull apart to fix
Apr 12, 2013 | Motorcycles
I have a Trek Lime bike with automatic shifter and it doesn't shift up quickly enough especially when riding slowly.
The automatic shifter mechanism on these bikes is driven by centrifugal force of weights near the rear axle. As they spin, they expand and move you to a higher gear. Although it's not a precise relationship, the mechanism is designed to shift to a gear that will give you a pretty constant pedal rpm - probably around 50 rpm. - regardless of the speed that the bike is moving. This is because as you ride longer distances your legs are most efficient at pedaling at a fairly constant speed (bikers call this cadence). Bikers who ride a lot find that these automatic shifters tend to keep you pedaling too slow (they find 70 rpm or even higher to be a better cadence.) However, if the cadence is too fast for you, you could alter the shift pattern by adding a bit more weight to the weights that are already there. You could do this with fishing weights and wire ties. This would give you a slower cadence. But as you ride the bike more you will probably find that you will want to remove the extra weights. I suggest that you keep riding without adding the weights and you will find that the preset cadence becomes more comfortable with time. It is also easier on your knees to have a faster cadence with lower pedal pressure. Good luck, Al K
Jun 20, 2011 | Cycling
The gears will not change at all. It seems like the part that you twist to change gears is seized on both sides. This is causing the bike to ride very slow.
Actually, it's causing you to have no gearing options. If you were Lance Armstrong the bike would move fast ;0) even with a flat tire.
http://www.parktool.com/blog/repair-help/shift-levers-shifters
Crimped, corroded shifter cables can prevent accurate shifting. I'm thinking you need a bike mechanic to look at it.
After it's all fixed you might want to view some resources concerning shifting, braking and general riding skills. It's all out there.
Feb 23, 2011 | Pacific International Pacific Evolution...
Hello, I just bought this bike from Target and took it for a ride this week. I don't know what gears to keep it in for it to ride like a normal bike. Is there a standard gear to make it ride (without...
Google this "how to shift gears on a road bike" and choose from the many videos and articles.
The gears are there to allow you to match your effort to the conditions. It pays enormously to understand how to manage them.
http://www.sheldonbrown.com/gears.html
Though I am an experienced cyclist and don't need to be taught shifting I thought this video was pretty good and gave him a buck for his efforts.
http://bicycletutor.com/gear-shifting/
Feb 11, 2011 | Cycling
I have a 1984 Harley Davidson ,transmission problem:does not shift into 3rd gear after riding 25 miles.Just need some ideas what this problem could be.
Ok, we need to determine whether you have a transmission problem or a clutch problem. Ride the bike until it will no longer shift into third gear. Then stop the bike and turn the engine off. While rocking the bike backwards and forwards, try to shift the transmission though all the gears. If it shifts through the gears there, you have a clutch problem if it will not shift though all the gears, you have a transmission problem.
Please try this and repost with me. I need to know whether your transmission is a five speed or four speed. I seem to remember that those bikes had a four speed that year.
Let me know what you find.
Good luck
Steve
Sep 28, 2010 | 1993 Harley Davidson FXR Super Glide
1994 sportster xl shifting problem
Make sure your cltuch is disengaging. With the motor full hot (ride it a good while), shut iff the engine, put it in first, pull in the clutch and try to roll the bike. It should roll as easily (or almost as easily) as it would in nuetral. If it resist, loosen the clutch adjustment so it has plenty of free play in the lever. Ride and see if that makes a difference. If not, most likely you have a bent shift fork or shif shaft. :(
Sep 11, 2009 | 2000 Harley Davidson XL 1200 S Sportster...
2003 SUZUKI GSXR 600 SHIFTING QUESTION I have a 2003 Suzuki GSXR 600 with only 2,500 miles on it (never been dropped or abused im the 2nd owner) and was riding it the other day at around 30mph and suddenly...
The transmission on your bike is not syncronized like a cars trans. When you are trying to shift from neutral at speed you must slow down to allow the gears to mesh. As far as having to rock the bike into gear sometimes, I have owned eighteen motorcycles of different sizes and makes and have had to rock all of them at one time or another to get them in gear. again lack of syncronization. It really doesn't sound as if you have a problem.
bigc
Aug 06, 2009 | 2001 Suzuki GSX-R 600
Shift Bicycle Gears
To shift gear properly, while riding the bike you be sure you are turning the paddles, and shift the gear.
Try to avoid shifting gears while riding standing up, this stress the gear system.
Oct 29, 2008 | GMC Denali 700C Road Bike
Cycling Logo
37 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
