SOURCE: 2001 Lexus ES300: front end wobbles at 50+ MPH....Bearings?
Could just be your tires need to be balanced. When was the last time you had them balanced and rotated?
SOURCE: Front end wobble in 1999 Chrysler Intrepid.
Take the car back to where you had the brakes checked, and tell them since then there is a front end wobble. Something doesn't smell right.
An easily overlooked problem that can have these symptoms is low tire pressure. Examine your tire for excessive wear or a flat spot. Check your tire pressures. If all this seems fine, rotate your tires to see if that helps the problem. If so, replace the suspect tire.
SOURCE: bad wobble in front end
somethings loose jack up front of car put hands @3and 9 oclock check for any play if their is see what moves
If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
SOURCE: 1998 s70 wobbles front end at low speeds
Go to an Alignment Only Shop & have them road test
while you ride along
Then have them inspect for worn parts
