Question about Linksys Wireless-G WRT54G Router
Router failure I had a power surge today and now my router does not work.  The only way I can connect to the internet is if I connect the modem directly to the computer.  Does this mean I need a new router or can it be fixed?
  • tolokata Nov 18, 2007
    I tried the hard reset and it did not work. I purchased a new router and the computer cannot detect it. Could it be a problem with the modem instead of the router after all?
  • tolokata Nov 19, 2007
    I installed the software before plugging in the router, per instructions. It is a Lynksys WRT5GS-BP. My modem is the one that my broadband provider gave me--Motorola SB5120. I received the "cannot detect modem" in the final step of the installation process on my main computer. My computer "geek" is coming later this week to help diagnose the problem but I was hoping to save some money by going through the blog process first.
  • 57 Answers
Just try to reset your router and enter again the router configuration..
Posted on Nov 16, 2007
    Brigadier General:
  • 6,966 Answers
As monterez has posted, pls try to do a full hard reset of the LinkSys WRT54G by pressing on the reset button at the back for a couple of seconds or till the led blinks. Pls remember the a hard reset will revert the LinkSys to factory defaults and you will loose all personal configurations. Thereafter, try the router again and see if you can log on to, if yes, then your set to go to reconfigure. If not, chances are the your unit would require replacement. Most of the time, the cost/time of repair would make the purchase of a new one more reasonable.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional; information.
Good luck and kind regards.
  • 1 more comment
  • Louie  Role
    Louie Role Nov 19, 2007
    Hi again,
    I doubt if it is a problem with your modem since as you posted initially, "...can connect to the internet..connect the modem directly to the computer..."
    Setting up your new router would best be done with a LAN cable. If it is another LiknSys, I believe that you have to install the software first before plugging in the router (or as per on screen instructions). If the installation instructions are followed closely and presuming no other problem with your system, then it should be a breeze. Otherwise, pls post back with your modem brand/model, your new router brand/model and your laptop or WiFi card brand/model.
  • Louie  Role
    Assuming everything is wired accordingly (modem to router to PC using LAN cables), pls try opening your browser and log to your router ( At the web configuration page for your router:
    Internet Setup -
    Internet Connection Type - Static IP
    Internet IP Address - 192.168.100. 2
    Subnet Mask -
    Default Gateway -
    DNS #s - what your broadband provider is using
    Save and reboot the router.
    This is again assuming that your cable modem can connect to the Internet.
  • Louie  Role
    Oooppps...."" should read as
My cable light dont blink
Turn off your modem (unplug it from the wall or surge protector).
Once you have done this, wait for at least ten seconds, if not one full minute. (This allows the modem to reset itself)
Plug the modem back into the wall or surge protector.
The modem will begin its start-up sequence and finally it should respond with a "blinking" connectivity light.
If you have a wireless or wired router connected to your modem you must make certain that you follow the next steps, or the router may not work to provide you with an Internet connection.
1. Unplug the Modem.
2. Unplug the Router.
3. Wait for one full minute.
4. Plug the Modem back in to the wall or surge protector.
5 Wait for the modem to complete its start-up sequence.
6. Plug in the router. (if you plugged in the router the same time you plugged in your modem, start at step #1 and try again...)
7. Wait for the router to finish its start-up sequence.
8. Test the connectivity to the Internet.
If this does not work, please add some clarification as to what service provider you are using, the type of modem/brand, and if you have a router...
Oct 22, 2012 | Televison & Video
I turned off the power to my 2wire box - now I can't get it to power up and have internet. What do I do??? More details: I had turned off the surge protector the 2wire box is connected to - when I turned...
Hi there!. unplug the power plug of your 2wire box from the surge protector for 1minute and after 1 min, plug in directly to the wall outlet, not to the surge protector. try to unplug and replug as well the connection on the back of your 2wirebox and check the cable connection from the isp cable to the modem,, the last option that your going to do is to reset the modem of your modem/router but make sure that you know the settings of your modem and wireless settings if u have.. or contact your isp provide for further details..there is a situation that there is a problem from your dsl company connection, most dsl use telephone lines..
Aug 14, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
No internet through router
There is a section in the router that says Status. In order to get to the router webpage, choose your start button and then choose Run. From there you want to type in the letters:
and then press the OK button
When the DOS like box opens, type in
ipconfig /all
Notice the line that gives you the Default Gateway, should have something like:
at the end of it.
Whatever the number is, mark it down. Connect your laptop or pc to the router. Pull up the 'web' and then try to visit the Default Gateway ip address instead of a website:
if it asks you for a user name and password, choose the password field and type in
hit the keyboard enter key and see if you can get into the router web page. If you can, then check the status section and see if you have WAN or Internet connection to Comcast or Cox or whatever your internet provider is... it should NOT say
If it does, then you want to make certain that the cable from the MODEM to the Linksys router is going directly into the router's Internet or WAN port. If this is the case, consider using another cable. If that does not work, you may be better off buying a replacement router. I have always had luck with a Netgear wgr614. It does not give you the fastest, but faster speed routers often requires unrealistic upgrades, and it not necessary for daily use if this Linksys router has worked well enough for you in the past.
Additionally, know that these routers are sensitive to power surges and a SURGE PROTECTOR, not a power strip, may be the smartest investment you can have for both your pc and your modem / router.
Jul 01, 2009 | Linksys Wireless-G WRT54G Router
No connection after lightning and thunder
There's ALWAYS the chance of damage.
If you have reset both the router and the cable modem and it still doesn't work, bypass the router and try connecting the system directly to the Cable/DSL modem. If your computer works in that situation the router has been affected, double check your connections between modem & router AND between router and computer.
If you still cannot connect, call your internet provider and inquire re: system status in your area. If all is good ask them if they can 'see' your modem. They will check their equipment to see if your modem is connected and communicating with their system. If they don't find it the modem is suspect.
If they can see the modem but you are still unable to connect to the internet via the router/switch, then the router/switch is the culprit.
Of course this all assumes everthing is OK with your computer. Otherwise this becomes a much larger troubleshooting issue. But let's not go there yet.
BIG TIP: Invest in a lightweight UPS or a line conditioner, particularly one that will protect your inbound Internet connection (coax or phone line) as well as the Ethernet port protection you need. In the end it's a LOT cheaper than replacing lightning damaged hardware.
Surge Protectors are of limited value because a majority (80% or more) of all power related electronic issues, especially regarding solid state circuitry, is due to BROWNOUTS, not surges. Something the manufacturers of surge suppression strips & related hardware are reluctant to admit, but that's why they can reliably afford to insure their surge protectors for ridiculous sums.
Apply this same principle to home entertainment systems, tv's (especially LCD & Plasma), game consoles, and any other valuable home electronics.
May 29, 2009 | Levelone CP TECHNOLOGIES LEVELONE...
Link 1 lit up and no more connection to internet
You may have been hit by lightning or power surge which knocked out one or 2 ports. If the WAN port is out you may still be able to use your router as a hub provided your modem can be configured as a router (many newer ones can) . Connect one of your working LAN ports to the modem and others to your computers.
May 22, 2009 | D-Link DI 514 Wireless Router (DI-514)
Very Slow internet after power outage
In that case reset the router and reconfigure it with the ISP settings,,there s a smallbutton on the back panel for hard reset but make sure if the router is old reseting might damage of luck
NB>if routers are old then power surge might damage it
May 15, 2009 | NetGear RO318 Router
Dell truemobile 2300 shows connected to internet, but isn't
When you reset the router, did you first shut the router down, then unplug the modem (wait 30 seconds), reconnect the modem (wait for all lights to go to "normal mode"), reconnect router to power, check for activity light on modem, wait about 30 seconds after all is powered up? If not, try that sequence and let me know if it works.
Mar 05, 2009 | Dell TrueMobile 2300 Router (000001)
Pc link
try bypassing the surge protector after turning everything OFF and then power on modem then router, without being connected to computer.
Jul 03, 2008 | Buffalo Technology (WLI-TX4-G54HP)...
Linksys Wireless-G WRT54G Router Logo
219 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
