... tool maintenance. This replacement bulb pack includes 2 on-carb primer bulbs and 1 remote primer bulb to suit your needs. ... RYOBI Fuel Line and Primer Bulb Tune-Up Kit. $10.97 ... Chat Icon Secondary ... homelite gas string trimmer.
1. Fuel tank dip tube (fuel filter) to siphon side of primer bulb
2. Primer output to carb in.
3. Fuel return to tank.
Likely you have reversed the primed bulb lines. Disconnect the line from the primer bulb to the carb. If you have the correct connection from the tank to the primer bulb, fuel will spurt out the bulb as you press the bulb
If no fuel, move the line at the primer bulb to the other primer connection. Press primer bulb a few times and fuel should spurt out bulb.
If still no fuel then a problem with the fuel tank dip tube or plugged filter
I believe that your question is in reference to the primer button on your carburator. If this is so and your button is pushed in then you will have to change the button. Take a pair of needlenose pliers and pull out the damaged primer bulb. Then go in with a pick tool and pull out the ring that is seated in the carburator at the bottom of the primer bulb. With the old primer bulb out of the carburator you can now install the new primer bulb. Put new primer bulb into place and with a dull punch slowly and very carefully seat the new primer bulb. This should put you back in business again. GOOD LUCK.
There should be two to four screws right around the primer bulb cover, which is located around the primer bulb. Remove those and switch the primer bulb out.
Hello. Unscrew the bad bulb. It unscrews in a counter clockwise fashion. Get a new oven bulb, of the same wattage at home depot or most hardware stores. J.
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
You need a "wet" primer bulb for the Jacobsen / Homelite snowblowers. A wet primer actually pumps gas - not air - a primer bulb with a hole in it was designed to pump air.
If you need a "wet" primer bulb email me and I will tell you where to get one for around $10 - basscatt at hotmail dot com
