SOURCE: My Bushnell Banner rifle scope
you might be able to buy a weaver rail adapter that can change your elevation aswell as lift up your scope a bit just to make it a bit easier to see out of. try something like this maybe http://ant-supplies.co.uk/DovetailtoWeaverAdapters.aspx
SOURCE: I'm trying to see what year my marlin lever action rifle is.
1883
Found here:
http://oldguns.net/sn_php/marlinlookup.php
Serial Number Prefix "Y" denotes year of manufacture as 1964.
SOURCE: How to determine the model and serial number of a marlin 22 rifle?
this is copied from a site, the web address is pasted below.
The serial number depending on the model of rifle, will be located either on the upper or lower stock tang, or side of the receiver.
http://www.gunvaluesboard.com/marlin-serial-numbers-dates-of-manufacture-1664.html
also if you find serial # you may find more info here.
From 1962 thru 1968 Marlins rimfire rifles (other than the 39 series lever actions) used a two letter date code that was stamped on the barrel. This date code is different than the one already listed, as Marlin rimfire rifles (other than the model 39 series) did not have a serial numbers until required to by Law after 1968. The first letter of the date code represented the month of manufacture while the second letter indicated the year. This date code was usually stamped on the left side of the barrel just in front of the receiver.
