Question about Kitchen Ranges
Wrong power chord I need to change from 3 prong to 4 prong.
  • 5,911 Answers
The following link describes how to convert from a 3-prong appliance cord to a 4-prong:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The difference is the way the Neutral (White wire) is configured. On a 4 wire configuration, the neutral is independent of the ground (Green) wire. Which means you DO NOT ground the white wire. Ground gets attached to the equipment cabinet or appropriate ground lug.
NOTE: This is for United States standard wire code. If you live outside the US, your wire color coding will differ. Please let me know if this is the case.
Let me know if you have any questions. I hope this helps you.
Posted on Jul 12, 2009
Convert 3 wire plug generator to 4 wire plug cord
First verify that the voltage is the same. It sounds like you have a single phase system which is 2 voltage circuits and 1 neutral. The 4th prong will be the ground. To do this properly you will need to get a new 4-wire chord for the generator with a cap that matches the one for your house. On the Generator side, the 4th wire will attach to ground.
Oct 04, 2017 | Dryers
Feul pump has 3 prong what to do to change to 4 prong on my ford truck
I would think you were given the wrong fuel pump
If it was the correct pump ,you would have update
instructions that would guide you & also answer your
question
Oct 11, 2012 | 1991 Ford F150
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
Jan 02, 2011 | Asko T701 Electric Dryer
Need to change a three prong power chord to a four prong
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Dec 30, 2010 | Maytag Dryers
Switched chords on dryer from four prong to three prong when plugged in the top left prong sparked did i fry my dryer or is this fixable?
This is probably fixable as you probably hooked the cord up wrong and it arced and likely blew the breaker before much was damaged. The 3 prong cord has obviously, 3 wires. As long as you get the middle wire in the the cord hooked to the middle terminal on the dryer, the other two wires can go to each of the outside terminals, no matter which one goes where. Correct the cord and you will probably be in good shape.
Sep 16, 2010 | Dryers
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
Lines on tv and a buzzing noise when the ps3 is turned on
then the only thing left to deal with is the system what you can do is send your system to the sony department and have them do a service check to see if anything is wrong with your ps3
May 22, 2009 | Sony Playstation 3 (PS3) Console
Changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
I hope this helps you. Let me know if you still have questions.
Nov 11, 2008 | Frigidaire GLER331A Electric Dryer
I need to change the power cord on our duet dryer from a 4 prong to a 3 prong The 3 prong does not have a neutral wire does that matter?
I think you need to read the following link to make sure you aren't violating any electrical codes, first:
Yes, a 3-prong DOES have a NEUTRAL wire. That would be the WHITE terminal. A 3-prong does not have a separate ground. The NEUTRAL is usually grounded at the appliance casing by a jumper wire.
Read in the "Additional Notes" section on how to convert from a 4-prong to 3-prong. Also note that some of the newer appliances require a 4-prong plug in order to run correctly. I have a Kenmore HE3 model dryer that is currently using a 3-prong power cord. Since this model Kenmore is manufactured by Whirlpool, and is identical to the Duet, you should be okay with a 3-prong plug.
Aug 08, 2008 | Dryers
Kitchen Ranges Logo
94 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
