Follow the shifter linkage back from the forward controls to the shift lever going into the transmission. Make sure the joints and bolts in the linkage are tight. My guess is the shift lever is loose on the shaft. If so, there is an allen head bolt that secures the shift lever to the shifter shaft. The shift lever is split and the allen head bolt is a pinch bolt. It's kinda hard to get to, but an allen head socket, short extension, and a rachet will work. Make sure this bolt is tight. Use a little penetrating oil before trying to tighten it. If it won't tighten, try taking the bolt out, chase the threads in the shift lever with a tap, and replace the bolt with a new one.
