Question about Cell Phones
Tryinging to load an alx application file to my blackberry pearl 8230. Went to desk top manager and followed instructions and got a fatal error when I tried to load it. I took the battery out and restarted my phone but is there something I need to do differently? (The alx file has a cod file in the folder with it and it is supposed to be blackberry specific.
Jvm error 102 on my 8230 bb pearl?
please go to these link if you want to perform this yourself: but please be sure to follow the instructions STRICTLY
http://supportforums.blackberry.com/t5/BlackBerry-Pearl-BlackBerry-8100/JVM-ERROR-545/m-p/71174
OR if you cant or dont want to do the steps or just want professional help, go to the nearest authorized balckberry shops, or from where you bought the phone.
Aug 18, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Tip
Load applications onto your blackberry.
<span> <p>To load applications onto your BlackBerry, you need to work closely with your PC. On your PC, you use an <span>application</span> called <span>blackberry desktop</span><i> Manager</i> (BDM), which comes on a CD along with your BlackBerry. Application Loader is a mini application within BlackBerry Desktop Manager.If you have an employer-issued BlackBerry, your company might impose guidelines on what applications (if any) can and cannot be installed and uninstalled from your device. Be sure to familiarize yourself with your IT department's policy before attempting to install or uninstall software from a company-owned BlackBerry.<span>Accessing the Blackberry Application Loader</span>After BlackBerry Desktop Manager is installed on your PC, do the following to access Application Loader:<span>1. On your PC, select Start --&gt; Programs --&gt; BlackBerry --&gt; Desktop Manager.</span>BlackBerry Desktop Manager opens.<span>2. Connect your BlackBerry to your PC via your USB cable.</span>Doing so connects your BlackBerry to your PC. If successful, you see the password dialog box. If not, check to see whether the USB cable is connected properly to both your PC and your BlackBerry and then try again. If all else fails, contact your service provider, or contact your system administrator if you're an enterprise user.<span>3. Enter your password.</span>This completes your BlackBerry-to-PC connection.<span>4. On your PC, double-click the Application Loader icon in BlackBerry Desktop Manager.</span>The Application Loader Wizard welcome screen opens. At this point, you're ready to use the functions of Application Loader.<span>Using the Blackberry Application Loader</span><br /> <p> <span><span><span> <br /> <span> <p>To install an application onto your BlackBerry from your PC by using Application Loader, you first have to install that application onto your PC. The installation onto your PC varies, depending on which application you choose to install, so be sure to refer to the manual that comes with the application you choose.After you get the application onto your PC, you need to locate the application's ALX file (a file with the .alx extension). The ALX file isn't the file that gets installed on your BlackBerry; rather, it tells Application Loader where the actual application file is located on your PC. You can usually find an application's ALX file in the folder where you installed the application on your PC.you can install it on your BlackBerry by using Application Loader as follows:<span>1. Launch Application Loader from BlackBerry Desktop Manager.</span><br /> <p>The Application Loader Wizard welcome screen appears.<span>2. Click the Next button.</span><span>3. Enter your password, and then click Next.</span>If your handheld isn't connected properly, you see the Communication Port Selection screen. Connect your BlackBerry to the USB cable and make sure that the USB cable is connected to the PC. Then click Next.The Handheld Application Selection screen appears. This screen lists the applications that are already installed on your BlackBerry.<span>4. Click the Add button.</span>An Open file dialog box appears, which you use to locate the ALX file of the application you want to install.<span>5. Locate the ALX file and then click Open.</span>You return to the Handheld Application Selection.<span>6. Click Next.</span>Doing so brings up the confirmation screen, listing the application to be installed.<span>7. Click Finish.</span>The installation process starts, and a progress window appears. When the progress window disappears - and if all went well - the application is on your BlackBerry<br /></span></span></span></span><br /></span>
on Nov 23, 2010 | Cell Phones
I have JUM error 102 on my blackberry pearl phone and now it wont power up, is there a way to fix it without having to replace the whole phone?
Try to put a good battery,if it still not working flash it with desktop manager and a new blackberry firmware.
Mar 20, 2010 | RIM BlackBerry Pearl 8100
I have the jum error 102 on my blackberry pearl however my phone occasionally returns back to normal why?
Hi, The BlackBerry smartphone stops responding, and the "JVM 102" error message is displayed: JVM 102 error occurs when there is an issue with one or more of the .cod files installed on the BlackBerry smartphone. To resolve this issue, perform a clean reload of the BlackBerry Device Software on the BlackBerry smartphone using the application loader tool. Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps: To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications to be loaded, and then click Next. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Clear the check box next to Backup up device data automatically during the installation process. Click Ok > Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following: Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 16, 2009 | RIM BlackBerry Pearl 8100
How to install an application for my blacberry cellphone
If you would liketoinstall application using the application loader tool in the Blackberry Desktop Manager.
You should verify that the application to be installed on the BlackBerry smartphone is saved to the computer before completing the following steps.
If you are using BlackBerry Desktop Manager version 4.5 to 5.0 then you need to follow this steps:
  1. Connect the BlackBerry smartphone to the computer.
  2. In BlackBerry Desktop Manager, click Application Loader.
  3. Click Start where it says Add / Remove Applications.
  4. Type your password, if prompted, and click OK.
  5. In the Device Application Selection screen, click Browse. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  6. Once the application is in the Device Application Selection list, verify it is selected, and click Next.
  7. On the Completing the Application Loader screen, verify the software to install is listed under Applications to be Installed or Updated, and click Finish.
If you are using BlackBerry Desktop Manager version 4.0 to 4.3then you need to follow this steps:
  2. In BlackBerry Desktop Manager, open the application loader tool.
  3. In the Application Loader Wizard, click Next.
  4. Type your password, if prompted, and click Next.
  5. In the Handheld Application Selection screen, click Add. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  6. Once the application is in the Handheld Application Selection list, verify it is selected, and click Next.
  8. Once the application is installed on the BlackBerry smartphone, click Close in the Application Loader Wizard.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 02, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
I get app error 523 every time on my blackberry 8220 pearl flip display
On the BlackBerry smartphone, the following error message appears after pressing the Mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
To resolve this issue, first perform a hard reset.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
If this does not resolve the issue, the BlackBerry® Device Software must be re-installed.
  1. Open BlackBerry Desktop Manager.
  2. Click Help.
  3. Select About Desktop Manager.
  4. Click the Device Software tab.
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click Application Loader.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Clear the check box next to Backup up device data automatically during the installation process.
  8. Click Ok > Next > Finish.
  9. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
  1. Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
  2. Click Next.
  3. Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
  4. Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
  5. Click Next > Finish.
The BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to open and run the application loader tool.
If BlackBerry Desktop Manager cannot connect to the BlackBerry smartphone, perform the following steps:
  1. Remove the battery and run loader.exe from C:\Program files\Common Files\Research In Motion\AppLoader.
  2. Remember to reinsert the battery after the loading operations begin.
Oct 26, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Blackberry flip jvm error 545
  2. Click Help.
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
Warning: The following procedure will delete either all data, or applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding.
To perform a full backup of the BlackBerry smartphone data complete the following steps:
  1. Connect the BlackBerry smartphone to the computer running BlackBerry Desktop Manager.
  2. Open BlackBerry Desktop Manager.
  3. Click Backup and Restore.
  4. Select Backup to perform a full backup.
  5. Select a location to save the backup file, and then click Save.
To perform a selective backup for one or more databases perform the following steps:
  4. Click on Advanced.
  5. Select the database(s) on the right side selection window for Device databases.
  6. Select the Arrow that points to the left side of the screen to transfer the database(s) to include in the backup.
  7. Verify the database(s) are on the left side selection window for the Computer databases.
  8. Click on File in the menu located at the top left hand side of the Desktop Manager.
  9. Name the backup file and select a location to save the file.
  10. Click the option to Save once the location for the file is selected.
Once you perform backup procedure, kindly then perform the following steps:
  • Click Ok > Next > Finish.
  • When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
  • To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:
    2. Click Next.
    Oct 22, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
    I was downloding a backup on my bb, i didnt remember the password so it gave me an error 513 what do i do?
    The Blackberry Device Software must be reloaded on to the BlackBerry smartphone.
    1) Open BlackBerry Desktop Manager.
    2) Click Help.
    3) Select About Desktop Manager.
    4) Click the Device Software tab.
    5) Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
    For instructions on how to download the latest versions of BlackBerry Desktop Manager and BlackBerry Device Software follow the steps:-
    1) Click the BlackBerry Device and Desktop Software link. 2) Click the Download BlackBerry Device and Desktop Software link.
    3) Select the appropriate software from the drop-down list and click Next.
    4) Click the Download link.
    To perform a full backup of the BlackBerry smartphone data complete the following steps:-
    1)Connect the BlackBerry smartphone to the computer running BlackBerry Desktop Manager.
    2) Open BlackBerry Desktop Manager.
    3) Click Backup and Restore.
    4) Select Backup to perform a full backup.
    5) Select a location to save the backup file, and then click Save.
    To perform a selective backup for one or more databases perform the following steps:-
    1) Connect the BlackBerry smartphone to the computer running BlackBerry Desktop Manager.
    4) Click on Advanced.
    5) Select the database(s) on the right side selection window for Device databases.
    6) Select the Arrow that points to the left side of the screen to transfer the database(s) to include in the backup.
    7) Verify the database(s) are on the left side selection window for the Computer databases.
    8) Click on File in the menu located at the top left hand side of the Desktop Manager.
    9) Name the backup file and select a location to save the file.
    10) Click the option to Save once the location for the file is selected.
    1) Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
    2) Double-click Application Loader.
    3) Click Next to start the installation process.
    4) Type your BlackBerry smartphone password, if prompted, and click OK.
    5) Select the check boxes next to the names of the applications to be loaded, and then click Next.
    6) Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
    7) Clear the check box next to Backup up device data automatically during the installation process.
    8) Click Ok > Next > Finish. 9) When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
    To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:-
    1) Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
    2) Click Next.
    3) Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
    4) Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
    5) Click Next > Finish.
    Oct 16, 2009 | RIM BlackBerry Pearl 8100
    (french)i have bberry curve 8330 and i receive a eror code 205..
    If it is application error then follow these steps: Warning: You should not install a version of BlackBerry Device Software that is earlier than the version installed on the BlackBerry smartphone. Doing so could cause the BlackBerry smartphone to malfunction. Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the computer by completing the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications you want to load, and then click Next. Click Advanced, and then select the check boxes beside Erase all application data and Erase all currently installed applications . Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager Note: BlackBerry Desktop Manager 4.3 will display the Delete all application data and Delete all currently installed applications check boxes in step 6 of the above procedure. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Add/Remove Applications. Type your BlackBerry smartphone password and click OK. Select the check boxes next to the names of the applications you want to load. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Click OK. Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager. Note: The Delete all application data and Delete all currently installed applications options are not available when using the Application Loader in BlackBerry Desktop Manager 4.5. A workaround for this issue is to use the Application Loader standalone file by performing the following steps: Open My Computer (or Computer in Windows® Vista?). Navigate to C:\Program Files\Common Files\Research In Motion\AppLoader. Run the Loader.exe file and follow steps 3 through 9 above to complete a clean installation of the BlackBerry Device Software.
    Jun 09, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
    I get this: App error 205 / reset - Hour glass keeps running. I removed the battery several times.
    May 26, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
    Cell Phones Logo
    46 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
