OUR WIRES CAME LOOSE ON OUR THERMOSTAT AND WE ARE TRYING TO PUT IT BACK TO GETHER.
  • Dave Dobransky May 11, 2010
    how many wires and what thermostat?Make sure power is off at the furnace
    Champion:
  • 233 Answers
I assume you are working on a central system, the wires should be color coded, the standard codes arre Red- connects to RC/RH with a jumper between the two, white- connects to W, Green connects to G, Yellow connects to Y and if equipped Blue connect to C or B, if it is a heat pump then Orange will connect to the O terminal
Posted on Jul 12, 2009
I want to put back my wires to grill element how on AEG E4100 1 OVEN
Unfortunately, this isn't a wiring diagram but can also serve.
See the pictures below:
Dado
Apr 24, 2015 | AEG Ovens
How do I free stuck valve on 16 hp or ck see if bent?
Guessing that it is a twin... even if one is messed up some how the other will compinsate for the one. Just a thought did you some how switch side on the spark plug wires ?
Oct 03, 2012 | Garden
Whilst printing I got a paper jam, I looked for source, and removed process unit, it came out in two pieces tottaly separated ? a spring & small piece of plastic has become dislodged and cannot be put...
Try to remove them and get them out of the way. Make sure nothing else is loose. Try printing. If you can print, I would not worry about those pieces. If not, try to find a diagram of how those go back in.
Mar 01, 2011 | Office Equipment & Supplies
Over heating already replaced thermostat new radiator new bottom hose new water pump it is still over heating
You seem to have done all posibilities. A test though to try would be remove the thermostat, put it back to gether with-out it and run the engine. Also, if you do that try it with the rad cap off so you can see if the water is circulating. It wouldn't if the water pump impellors are damaged.
good luck!
Sep 29, 2010 | 1992 Toyota Camry V6
I just replaced my pool pump motor and it runs fine now but will not shut off. I did not mark the wires when I removed them as I didn't think it mattered except for the ground. When I reconnected the...
SOUNDS LIKE THE TIMER POINTS MIGHT BE STUCK TO GETHER.. SWITCHING WIRES DOES NO GOOD... SOO THE WIRES THAT COME FROM THE BREAKER GO INTO THE TIMER, IF YOU LOOK AT THE BACK SIDE OF THE TIMER YOU CAN SEE HOW IT WORKS, THE OTHER TWO GOTO THE MOTOR.. ITS NOT ROCKET CHEMISTRY
A VOLT METER CAN BE YOUR BEST FRIEND..
Sep 12, 2010 | Garden
Blower motor will not come on. i have a rheem furnance
Turn your fan from auto to on at thermostat, if fan doesnt come on.
Remove blower motor door to get to control panel-Turn poweroff !
Try to turn blower wheel to see if it will turn freely,
Remove thermostat wires from control board, put a jumper wire between
r and g.Put door back on and restore power, fan should run. If it does
than it is possible you have a burnt out speed on whatever cylcle heat/cool you are trying to use.
To troubleshoot this-turn power off and find where the blower wires go to
control board. exchange the wires from park to heat or cool terminals.
put cover back on and restore power.IT should work,if nothing happens then you probably have a problem with blower
Feb 13, 2010 | Heating & Cooling
Blower does not work and heating element heat with
Check for power to the unit. If power exists, check your low voltage. Do you have 24volts to R & C at your thermostat?
Feb 07, 2010 | Goodman GMS90703BXA Heater
Can I connect the left front and rear together and same on right?
you can.. im guessing your trying to do that to "bridge" the amp to put out more watts.... you can do that but it puts a lot of strain on the amp that is pushing the speakers..(the radio)
Oct 18, 2009 | Pioneer TS-A6962R Car Speaker
Location of the thermostat on a elantra 2002
follow the top radiator hose to the engine and that is where you will find the thermostate housing. drain the coolant completely then pul the housing off. make sure when you put in the new thermostat that you put it in that same way and direction the old one was. clean and dry housing before installing gasket and putting back to gether. refill the cooling system, and run with cap off for 30 min topping of the fluid as needed. run for 15 minutes with cap on making sure to keep an eye on the cars temp gauge. after done drive the car for at least 15 miles let it cool down and ceck the coolant level.
hope this helped
please rate well
Mar 04, 2009 | Hyundai Motor 2002 Elantra
Wine cooler haire hvw18bss - no power/ will not run
hi geneglass,no rest ,they are built into unit.first fin thermostat and put the two wires together[unit unplug first]then when to gether plug in.the thermo controls run time.if not doing it will need volt meter to check at compresor relay.please help with my ratings if i have been helpful.god bless you,tom
Jan 02, 2009 | Haier BC112G Wine Cooler
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
