Question about Broderbund PrintShop Pro Publisher Deluxe 20 for PC
The print shop is not cropping correctly. Once I have the image I want to crop ready and click on applty crop the image crops another area such as the feet of a person.
You have to choose area effects tab first, click on the area (aprox) where you are going to crop, then choose crop and orientation tab and do your croping. I don't know why it works like this, but this has solved the problem for me.
Posted on Mar 25, 2010
PS CS6 How to drag a layer into another PSD file at-size?
>Open "My Computer" from your desktop. Double-click your hard drive.
>Open "Documents and Settings."
>Open the folder labeled with your user name.
>Open "Local Settings" followed by "Temp."
>Scroll down to the files beginning with "Photoshop" ("PS" for older Photoshop CS builds). This will be followed by a series of letters and numbers.
>Double-click each "Photoshop" ("PS") temp file to open them in Photoshop CS. This is the only way to identify which temp file contains the project you wish to recover. Luckily, because when Photoshop shuts properly it deletes its temp files, there should be no more than three or four.
>Select "Save As" from the "File" menu when you find the temp file you want. This will make the file permanent.
also use Photoshop Restore Toolbox
http://www.photoshop.restoretools.com/
Apr 25, 2015 | Adobe Photoshop 7.0 for PC
How can I crop a picture?
Download an efficient image software like Irfanview (www.irfanview.com)Select the area. Then Cntrl +Y to crop the image. Save the cropped image with a different name. > Siddhartha Basu, India
Jan 01, 2010 | Canon PowerShot A400 Digital Camera
Opening saved Gimp file
Hi Amber.
If I read rhe above correctly, you have got your last saved image back. You had only marked out areas to crop, you hadn't cropped them.
It follows then that you hadn't made any changes to the file.
Sep 13, 2009 | GIMP GNU Image Manipulation Program
HOW TO RESIZE PICTURE AT ADOBE??
To resize an image with Adobe Photoshop Elements 4.0 you first need to open the image. After opening the image you will select Image---> Resize---> Image Size. If you select canvas size the image itself will not change.
At the Image Size menu, make sure that the "resample" check box at the bottom of the menu is selected. Then enter the desired resolution and width/height. For printing an image, a resolution of 300 pixels/inch or more is desirable. When images are intended for computer or web display, 72 pixels/inch (sometimes referred to as dpi) is sufficient. You can set the image size in pixels (at the top of the menu) or in inches (at the lower part of the menu). Once the desired sizes are entered you only need to press "ok" for the change to be made.
Photoshop Elements also offers another method of resizing an image. You can use the "crop" function to resize your image quickly. The crop tool looks like a small square with overlapping edges and can also be accessed through the Image menu bar at the top of your screen.
Once the crop tool options bar opens, select "custom" and then enter the desired height/width and resolution. To crop to specific pixels you must enter the letters "px" after the size number in the width/height boxes. If only one dimension is important you can enter information in only one box and let the other dimension be determined purely by where you place the crop line.
After entering your preferences you will click and drag the crop tool across the image to select the part of the image you wish to keep.
Jul 17, 2009 | Adobe Photoshop 7.0 for PC
Command Action
Open - Window - Action. Click on arrow on top right. Create New Action name it, and record an action by cropping one of the images.
Go to File - Automate - Batch. And choose folder with images you want to crop.
Apr 05, 2009 | Adobe Photoshop 7.0 for PC
How to crop?
Select the area you would like to retain by draging across and click crop. (Normally it is found under EDIT command ) It is extremely simple
S. Mohan
Mar 18, 2008 | Canon DR-1210C Scanner
Multi-crop
In the settings TAB you need to specify the Area OR BAND that you wanna cut and where you want your cropped image to be saved thats it .
Feb 12, 2008 | Canon CanoScan 8000F Flatbed Scanner
Scanning Problem
Scanned image is unsatisfactorily cropped
You can turn auto-cropping off or adjust how the image is cropped.
To turn auto-cropping off:
From your desktop, double-click the Lexmark X6100 Series
All-In-One Center
icon.
The All-In-One Main Page appears.
2 Click See More Scan Settings.
3 Click Display Advanced Scan Settings.
4 Select the Scan tab.
5 Click Select area to be scanned, and then select a size from the
drop-down menu.
6 Click OK.
To adjust how the image is cropped:
All-In-One Center
icon.
4 Click the Scan tab.
5 Select Auto-crop the scanned item.
6 Slide the Tolerance bar to the left to crop less or to the right to crop
more.
7 Click OK.
Dec 06, 2007 | Lexmark X6170 All-In-One InkJet Printer
Indesign Crop Mark and nudge
To crop or straighten images in Camera Raw
In the Camera Raw dialog box, select the Crop tool or Straighten tool .
(Optional) If you want the crop area constrained to specific proportions, click the Crop tool icon and choose a proportion from the pop‑up menu. Choosing Custom opens the Custom Crop dialog box, where you can specify the proportions or the dimensions of the crop. Click OK.
Do one of the following:
To crop the image, drag the Crop tool over the image.
To straighten the image, drag the Straighten tool in the preview image to establish what’s horizontal or vertical.
(Optional) To adjust the crop area, do one of the following:
To scale or rotate the crop area, drag just outside the bounding box handles.
To move the crop area, click in the bounding box and drag.
If you selected several images in the Camera Raw dialog box, they are all cropped to the same size, with the crop applied in the same position.
Note: To cancel the crop operation, press Esc with the Crop tool selected or click the Crop tool and choose Clear Crop from the pop‑up menu. To cancel the crop and close the Camera Raw dialog box without processing the camera raw image file, click the Cancel button or deselect the Crop tool and press Esc.
Click Open, Done, or Save to apply the crop and process the camera raw image file.
Oct 20, 2007 | Adobe InDesign CS2 for PC
Process Cropping
Most digital cameras have an aspect ratio of 4x3. 35mm cameras have an aspect ratio of 3x2. 6x4 photopaper also has an aspect ratio of 3x2. Therefore you don't get cropping when printing from 35mm film. To make the picture fill out the 6 inches, the digital footprint has to be 6" by 4.5". So .5 inches is removed in the process. If you can find a processor that will print 5.333 x 4 on the 6 x 4 paper, there would be no clipping necessary. Since you have Photoshop, you can crop the photo to a 3 x 2 ratio. That way you control what is cut. I use Photoshop Elements and when I use the Rectangular Marquee Tool, I set Style to "Fixed Aspect Ratio" and Width to 3, and Height to 2.
Sep 14, 2005 | Creative Labs PC-Cam 300 Digital Camera
Broderbund PrintShop Pro Publisher Deluxe 20 for PC Logo
466 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
