Product Support & Manuals - Frigidaire
www.frigidaire.com/Owner-Center/Product-Support-Manuals/
FrigidaireFind appliance guides and manuals, FAQs, information about accessories and more. Get all of the answers you need about your Frigidaire appliance today.Dishwashers - Ranges - Window Mounted Air ... - Washers
SOURCE: kitchen aid top loader washing machine does not spin
Peace Friend,
ngfam1 At your service!
Sounds like a belt problem!
Or the linkage connecting the transmission to the agitator.
Or the WORST THE TRANSMISSION IS GOING!
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
SOURCE: Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
SOURCE: kenmore he2 front loader washer won't do rinse spin cycle
kappharmd-
if yours is the same, the drain is hidden behind the lower access panel on the front (how convenient, huh?). I don't understand why they didn't just make a recess hole for it. I've just left one screw loose in the center and it kinda "compression" fits. We clean this out regularly, as my wife and family don't check pockets well. :)
SOURCE: front loader wont spin
Hello there:
It doesn't spin
If your washer won't spin, check these:
If the motor is running, the lid switch may be
defective. If so, the washing machine can't spin and may not function at
all. The switch is inside the washing machine main housing near the
door frame. Often you have to raise or open the top or front of the
washing machine to get to the switch. If it's defective, you need to
replace it
The motor coupler may be broken. Many
Whirlpool®-manufactured washers use a small, relatively inexpensive
motor coupling. It's plastic and rubber and is mounted to the shaft of
the motor on one side, and to the transmission on the other. Over time,
the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one
or two belts. If a belt is broken or badly worn, you need to replace it
with a genuine belt from the manufacturer. (Some washing machine belts
are designed with special characteristics not found in automotive
belts.)
The clutch may be worn. If your washer is a GE, it may
use a clutch to come up to the proper spin speed. As the clutch wears
out, it may prevent the unit from spinning well or at all. If the clutch
is worn, you need to replace it. For this job, you probably want to
hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands
use a reversing motor. For agitation the motor runs in one direction,
for spinning and draining, the other. It's possible for a motor to burn
out in one direction and continue to operate in the other. If this
happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older
washers produced by Whirlpool® have a transmission with an
electro-mechanical shifter. If the shifter becomes even partially
defective, the unit may drain the water but not spin. This is a complex
system, if your washer has a shifter problem, you may want to hire a
qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or
seized. These components allow the inner tub to spin freely inside the
outer tub. When this is the problem, you usually hear a loud sound
during the spin cycle.
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
