Question about Panasonic PT-47WX53 47" Rear Projection HDTV
TV turns off
I have a panasonic rear projection HDTV I changed the IC's and 6 of the little fuse like things put it back, when i turn it on it waits a couple of seconds then turns off. The automated diagnostic blinks one time on the front of screen.
  • 2 more comments
  • dserrano2006 Jul 12, 2009
    I have replaced them both.
    I have rechecked all the connections it still shuts off.
  • Rob Sinpasit May 11, 2010
    do you have 1 or 2 IC, i would replace them both if you have 2, if one goes out others will soon to.
  • 10,594 Answers
One blink error shows problem of +140 volt missing in TV
Please check if any connector is not plugged correctly while you put back things.
Posted on Jul 12, 2009
Panasonic PT-61LCX65 turned off while I was watching TV. Won't come back on. "Lamp" light blinks once every 5 seconds. Tried turning it on several times per the manual instructions--no change....
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Feb 25, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic tv turns volume down by its self
there might be something wrong with the tv remote. turn the tv on then make it on a high volume then put the remote in a different room and see if the volume turns down if it doesn't then you have some thing wrong with the remote not the tv.
Jan 15, 2011 | Panasonic PT-50LC14 50" Rear Projection...
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My panasonic rear projection tv will not power on and no lights turn on. Any suggestions?
Please plug TV in another power source and turn it ON,
if still does not turn ON, unplug AC wire of TV, take off back cover and follow AC cord f TV that will take you in power supply board, find fuse nearby and check is it blew off? if yes, replace it with same ratings written on it.
Plug TV in AC wall socket and turn ON, if fuse blow again that means power supply section in TV got problem and need qualified tech to find out and replace components or power board.
Thanks.
Sep 18, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Projection HDTV won't power up, red LED flashes in front
i am having same problem. 3 flashes indicate convergence problem according to auto diagnostics that you are seeing(info from service manual).
i am starting by replacing stk392-110 convergence amp ic($6 at electronic.com). just ordered them, will let you know how it goes. please check this site-- http://biobug.org/ht/panasonic/ -- very good step-by-step on procedure.
will need service manual afterward. email me if you want copy.
good luck and godspeed,
bridgeman001
Apr 17, 2009 | Panasonic PT-53WX52 53" Rear Projection...
The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
no the 6 blinks indicates a missing voltage. If your talking about a sony lcd KD or KE model you probably have a bad thermal fuse. You must also clean or change the Lamp fan so it won't blow again.
Apr 16, 2009 | Sony KP-53HS30 53" Rear Projection...
TV powers up, but the picture won't come up. TV then trips back off.
check out the fuse on the main boasrd of the tv.if that is perfect then its the problem of  ic number 432 on the main board thats getting overheated. it needs replacement.
Mar 07, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic rear projection tv air filter
heres what you do remove front panel "little black door below the screen" get some software cleaner "air" clean all in that box that you just removed the cover from also you might try cue tips and alcohol let dry thoroughly put cover back on and turn on tv it should work if the message comes on again turn the power on and off about 6-10 times and turn back on it should turn on and be fine .if that happens again just open the cover and blow with sopftware clean.sound wierd but after alot of experimenting i fixed my tv that i bought as a salvage because of that error message bhope it works
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic rear projection model #- PT53WX53G will not turn on.
Happened to me, relays, either 1 of 2 so I had both replaced, about $300.00 to fix.
Nov 16, 2008 | Panasonic PT-53WX53 53" Rear Projection...
TV turns off and won't come back on
You have a pair of defective IC. Part Number stk392-110
Dec 08, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
110 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
