Question about Canon imageRUNNER 5570 Copier
Cannon Image Runner 5570
I need to find out where the waste toner container is located for replacement, got any suggestions to where I can find it.
  • 1 more comment
  • JoeyJoJo Dec 19, 2007
    I cannot find where the watse container is either, and I do not know what to look for.
  • Anonymous Mar 14, 2008
    WHERE IS THE WASTE CONTAINER?
  • Anonymous Mar 27, 2009
    Can't locate the waste toner container on IR 5570.
  • Canon Expert
  • 270 Answers
If the copier is indicating to empty waste toner bottle do as previously described. Until you reset the copy counter for the waste toner you will still get the message. Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's.
Posted on Nov 17, 2007
    Problem Solver:
  • 6 Answers
The waste toner container is located under the on / off switch. There are two screws on the panel that need to come off before the panel can come offCannon Image Runner 5570 - _422.jpg
Posted on Jan 06, 2011
  • 69 Answers
Hi im jules_09,you can finrd it at the lower right of the machine besides the paper tray 1,2,3,4.its just aplastic bottle or a plastic container
Posted on Nov 16, 2007
    Problem Solver:
  • 19 Answers
The waste toner box is behand of machine and you don't need to replece, clean only ok
Posted on Jul 28, 2009
How do I fix cannon image runner e 000019-0000?
DEAR
its indicating the waste toner full. Get clean the waste toner box and reinsert it. If problem persists then the clean/replace the waste toner sensor. Check the harness of this sensor to DC CON board.
Thanks.
Jan 28, 2015 | Cannon Office Equipment & Supplies
Replace waste toner container imagerunner c7065
On the right side of the copier towards the back lower corner you will find the cover to the waste toner tank, a single screw holds it in place, remove the cover panel, behind it is a large plastic bottle pull it out empty it put it back in, pay attention on how it comes out so you will be able to replace it, may have to pull the lid holder out first.
To clear the error after changing the waste toner container on Canon C7065 Image Runner Advance, from the control panel, click on the setting/registeration button. Logon to the machine, you will need admin ID # and pin #, Once logged in pick adjustment/maintenance, on the next screen pick maintenance, then use the arrow key and chose page 2 on the next screen touch initalize after waste toner replacement.
Apr 01, 2012 | Office Equipment & Supplies
Cannon IR 33201 error e000019-0000
this is error for waste toner, and the waste toner needs to be cleaned.
On left sideway of copier, in lower left corner you will see the plastic cover with one screw.
Remove the plastic cover and remove waste toner box by pulling toward you. Empty it and clean the neck of the bottle. Put it back in and restart copier,
Hope that helps!
Aug 18, 2011 | Canon Image Runner 3320I Copier
Where would I finf the waste toner container on a Canon Image Runner IR3300?
On iR2200/2800/3300, waste toner container is located on left sideway of copier.On left sideway, in lower left corner, you will find the plastic cover with one screw. Unscrew it, and remove cover ( it goes out under strange angle ). Pull out the bottle, and clean it and dry it verry well.After you can use some alcohol to remove ESD from bottles "neck".
Also you can pull out the wires above container, that is waste toner sensor, when you disconnect it, it will no longer report E019, but you need to have in mind to clean the bottle every 50000-70000 copies.
Hope that helped!
Jun 28, 2010 | Canon imageRUNNER 2200
I cannot find the location of the waste toner bottle.
On iR 2200, the waste toner container is located from left side of copier. To be precise, on left side are door with handle (wich is opend to reach paper in fixing assy or duplex), beneath this door ( left lower section from the door ) is small cover with one screw, when you remove it you will be able to see waste toner container. Its a plastic botlle, remove it clean it and dry it.
Feb 28, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Cannon image runner 2200 Error code E000019-0000
Empty the waste toner container. From left side of copier you have small cover with one screw.Remove the cover and empty the container and clean it very well, you may use alcohol for the neck of the bottle to ged rid of of antistatics.
Nov 24, 2009 | Canon (6981A002AA) for imagerunner 2200,...
How do you reset a cannon Image Funner 5570 down
I hate to say it but you have to replace the main motor. E010 is a bad main motor.
Sep 07, 2009 | Office Equipment & Supplies
A message is poping out saying replace the waste toner container.
I'm taking it that you have a IR-2270, not a IR-5570 correct??? The waste toner bottle is behind the front cover... It is in front of the drum unit. It is measured by the weight of the bottle, you just need to empty the bottle and you should be all set.... There is one screw in next to the toner bottle.... The other one is on the top left front corner of where the paper comes out. You have to push the front pannel to the left to remove the cover... Good Luck
Apr 14, 2009 | Canon imageRUNNER 5570 Copier
Waste toner
Turn off the copier. Remove the lower left panel on the left side of the copier, then pull out the plastic container and empty it. Reinstall the container and cover then turn the machine back on.
Apr 08, 2009 | Canon imageRUNNER C3170U Color Copier
Cannon IR 2200
OK i am having the same problem but here is the solution that I have found online that I am going to try in the next 5 minutes:
waste toner container is placed left-rear side of the machine. Take out one screw,small cover will come out then pull out plastic container. Empty the container and clean the head really well as this can cause problems with the fuser.
good luck!
Aug 26, 2008 | Canon imageRUNNER 2200
Canon imageRUNNER 5570 Copier Logo
2,186 people viewed this question
old marine
old marine
