Question about Kenmore Elite 45986 Front Load Washer
Water pump gets hot, then I get an f02 code .
  • 5,911 Answers
"F02" is a Long Drain error code, which is usually an indication of a pump clog, pump malfunction or drain hose clog. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
If you have already attempted to clean the drain pump reservoir, and if you've confirmed you have no clogs in the drain lines anywhere, you may have a bad drain pump. Especially, if its running hot like you've described. Replacing the pump is not a difficult repair. You can purchase a new one at searspartsdirect.com, appliancepartspros.com, repairclinic.com or pcappliancerepair.com. All these sites offer competitive pricing, so shop all of them for the best price. If you need instructions on how to replace the pump (if required), the following link provides step-by-step instructions:
http://www.fixya.com/support/r401841-replacing_kenmore_elite_water_pump
If you have any questions please let me know. I hope you find this information helpful.
Posted on Jul 12, 2009
My whirlpool duet washer had a F02 code now it won't pump water
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Aug 24, 2014 | Whirlpool Washing Machines
I am getting an f2 error and when I put it on drain/spin and lift the hose then lots of water starts to drain it takes about 2 times before it will spin and the water is gone
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Jan 06, 2011 | Washing Machines
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
Will not drain. Getting error code F02
yes exactly.you are right.its the pump problem. F/02 error code:-- Long DrainIf the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
try this :-- Press PAUSE/CANCEL twice to clear the display.
:Check the drain hose and make sure it is not plugged or kinked.
: Check the electrical connections at the pump and make sure the pump is running.
: Check the drain pump filter for foreign objects.
: If the above does not correct the problem, replace the pump.
you can get required parts from www.repairclinic.com
Nov 27, 2009 | Kenmore Washing Machines
Getting f02 and suds error mesage
HI. this code represents a Long Drain issue.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
Sep 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
After f02 code came up ran a test and get c00 andhttp://www.fixya
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Sep 27, 2009 | Kenmore Washing Machines
F02 whirlpool washer
HI, check the descriptions below to address this issue.
F02 Long Drain
Potential Causes
Jul 08, 2009 | Whirlpool Washing Machines
Model GHW9150PW0 shows code F02. The washer did nor complete the spin cycle and water was left in the tub. How do I get access to the pump. How do I remove the panels. Thank you
Potential Causes
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02 Error on Front Load Kenmore HE3
F 02 Is your key pad user interface that has failed. I would call back and get some free service from a different technician.
Oct 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
73 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
