Question about Hunter Fan Co. 60 In.Brushed Nickel Stonebridge Remote Control Ceiling Fan
Hunter Fan - fan turns on and light goes off
When light switch is turned on, the light comes on for a moment and then goes off. The fan then comes on in the low setting. The remote doesn't seem to be connecting with the fan. When light switch is turned on, I hear a click in the part no. 85112-04.
  • 129 Answers
You need to check the wiring and make sure factory dip switch settings are set
Posted on Aug 23, 2009
2 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: I need a hunter remote control unit part
This particular Hunter remote control unit has been known to have interference issues for some time now. It is very suceptible to picking up other transmissions, such as those from TV remotes, etc.
If you're having intermittent operation of the fan and/or light, you can try setting different codes for both the receiver and the remote.
That being said, the best source for a replacement unit is directly from Hunter, since you might also still be under warranty you might get it replaced for free, if you remembered to fill out and mail the warranty card!
Of course, if you just want to replace a lost or broken remote, give them a call and order one (or two and have a spare!).
To speak with a live Technical Support Representative call: 1-888-830-1326 (United States) 1-866-268-1936 (Canada) Hope you find this Very Helpful and best regards!
Posted on Aug 21, 2009
My hunter fan light can't be turned on/off with the light switch
The switch will only turn the power on to the fan/light. You have to use the remote to dimm the light & change the speeds. You should be able to install it on the wall next to the switch so you can turn on your light when entering the room.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
Light switch will not turn on fan light, however I can turn light on manually, note I HAVE REPLACED THE LIGHT SWITCH AND THE RESULTS ARE THE SAME.
I'm assuming you can turn on light AT the fan but not at wall switch, And you have replaced WALL switch correct? If that's correct, then wiring above fan has come loose and is no longer attached to wire that connects to wall switch. (They come loose from fan vibration - had same problem)
Feb 27, 2011 | Hunter (25417) Ceiling Fan
Fan and lights comes on automatically
· If you installed more than one remote-controlled ceiling fan, set the DIP switches on both receivers and the control of one fan to an identical alternate sequence (such as "all up" rather than "all down"). Otherwise, when you turn off the ceiling fan in one room, it will turn off the fan in the adjoining room. You can also go to the internet and enter GOOGLE.com in the GOOGLE search box enter Hunter.com homepage. You should find all the help you need there.
If you found any of this information helpful, please rate my solution. Thanks D. Lange
Apr 23, 2009 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Mar 15, 2009 | Hunter Low Profile III 20807 Ceiling Fan
Light kit stays on low (like brown-out) while fan runs
I think the switch is wire wrong.To me it seem s that hot wire is in the wrong place
Mar 13, 2009 | Hunter 52" Ceiling Fan With Light And...
Remote control fan
I had the same problem and I thnk Hunter Fan knows about it....I just called Hunter Tecnical Support at 901-745-9222 and they sent me a new White circular receiver which goes inside of the canopy and it worked fine after installing the receiver....
Mar 14, 2008 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Remote control ceiling fan
Possibly a bad circuit board in the ceiling fans remote function. I would suspect that the circuit board has a thermal issue where once warm it works fine. The most common fault that I have seen is a bad solder connection on the board. Pull the board from the fan and check all solder connections for cracks or dull solder. If you see any of these then reflow the solder connections. If this does not work you probably will need to order a new board from the manu.
Jan 26, 2008 | Dryers
Hunter Fan Co. 60 In.Brushed Nickel Stonebridge Remote Control Ceiling Fan Logo
1,611 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
