Question about Hampton Bay 24002 Ceiling Fan
Yellow, purple, black, and orange wires and need L,1,2,3 connect.
Can someone help?
  • 4inlanguage Jul 12, 2009
    Anyone know which color go with each number?
    The fan isn't even coming on, with the black wire in the (L) slot.
    President:
  • 1,714 Answers
How many wires are coming up from the wall switch? If it's one black and hot wire one white, and your speed switch is on the fan, you connect the hot to the 'line' wire on the switch and the other colored wires are your 3 speed wires (high, med. low)
Posted on Jul 12, 2009
  • Craig Butler
    Craig Butler Jul 12, 2009
    Low, med, high, 1 2 3, You may have to experiment to find which one is which. Hook it up and see what you have...
    Problem Solver:
  • 6 Answers
NOT ALL SWITCHES ARE THE SAME!!!! Some are single layer and some are not!!. I think you can tell by the body color of the switch. Red and Black, Grey and Black, ETC. I figured this out after buying 3 of the wrong switches. Each one hooks up a little different. If it is an aloha brand fan like sold at WalMart it is a common issue. Just call there 800 number and they will send you a new one. You have to know the exact model number of have the bar code. Usually there is a bar code on top of the motor. Just take it down from the ceiling and look. I called them on Thursday and got a free switch and capacitor on Monday!! My fan is going great again. If you have the old switch check it or just call the fan's customer service!!
Posted on Aug 18, 2009
3 Suggested Answers
TBlessed 1
  • 61 Answers
SOURCE: ceiling fan wires
is the old fixture still installed?
Posted on Oct 17, 2008
SOURCE: I have the aloha model 5745, need to replace speed
when I turn my fan on, it will not come on, I can come back in the room in a few minutes and it will be on, whats my problem
Posted on May 22, 2010
I need to connect Orange, Yellow, Purple and Black wires from fan into the correct corresponding numbers on fan switch 1,2,3, L (0033906)
Try this; Orange - 1
Yellow - 2
Purple - 3
Black - L
If this doesn't work, you probably have the wrong switch. Just because a switch looks the same on the outside doesn't mean it's the same on the inside.
May 13, 2015 | Dryers
Need wiring diagram for a Pioneer stereo model AVIC-D3
Yellow - Battery
Red - Ignition
Black - Ground
Light Green - E-brake
Purples, greens, whites, and grays - speakers
Purple\white - reverse signal
Blue\white or Blue - amp turn on\ power antenna
Yellow\black - mute wire
Orange or Orange\white - illumination
Sep 03, 2010 | Pioneer AVIC-D3 Car DVD Player
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
I have the aloha model 5745, need to replace speed switch, which wires go where? yellow purple, black, orange;L 1 2 3
I'm an electrician and
I just replaced the speed switch on a 5745. This people at Aloha Housewares, Inc. were very nice and speedy in sending a new unit at no cost.
Connections are:
1=yellow
2=purple
3=black
L=orange
Jul 11, 2009 | Aloha Housewares (93645) Ceiling Fan
How to wire KD-S741R CAR STEREO - WIRE COLOURS ???
older pioneers:
2 x green (1 with black tracer) left rear spkr (black= negative)
2 x white (1 with black tracer) left front speaker
2 x grey (1 with black tracer) right front speaker
2 x purple (1 with black tracer) right rear speaker
Lower connector
1 x red ignition (switched supply)
1 x blue antenna output power (may not be not used)
1 x yellow Illumination (radio button lighting)
1 x orange permanant Battery supply
1 x black vehicle GND
If still not working swap yellow and orange wires! will not cause damage
May 12, 2009 | Car Audio & Video
I have a westinghouse three speed fan. there are 4 wires a black, purple orange and yellow . the new switch has four connectors L 1,2,3 does any one know witch goes where? thanks , i bought the new switch...
ok. hope this helps, use a switch from FANTEC. it'll be called a 3 speed fan switch. CAM #5 No. 21105. this will also say Single Layer 3 or 4 wire application SPLIT continuity function.. THE SPLIT PART IS VITAL. now when wire it. the BLACK wire goes in SLOT 3. ORANGE wire goes in L. PURPLE wire goes in slot 2, ORANGE wire goes in slot 1. IF, and i repeat IF this does not work for you ensure you have a SPLIT CONTINUITY FUNCTION switch. NO MATTER WHAT the BLACK wire WILL go into slot 3. the ORANGE wire WILL go in slot L. switch the orange and purple wires only. ENSURE POWER IS OFF WHEN CONNECTING OR DISCONNECTING WIRES. YOU WILL GET THE SNOT ZAPPED OUTTA YOU IF YOU DON'T. please post if this helps.
May 02, 2009 | Westinghouse Electric Westinghouse...
Ceiling fan wires
Oct 16, 2008 | Hampton Bay 24002 Ceiling Fan
I have a carrier AC model#50ee036330, the fan motor went out it was an emerson2 speed with 3wires.IMtrying to replace it with a GEMOTOR no.3586 with6 wires at 1 side and 4 on the other.6wires arered black...
jenny,White and black is high speed,wire nut the yellow and blue by themselves(2) brown wires cap.yellow brown together and orange and purple together they should be direction wires.If the fan runs backwards change them
Aug 14, 2008 | Carrier Heating & Cooling
Hampton bay ceiling fan
This should do the trick. Good luck and make sure the power is off.
L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
Jan 28, 2008 | Hampton Bay 24002 Ceiling Fan
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Hampton Bay 24002 Ceiling Fan Logo
1,437 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
