Question about Garden
My power washer has no pressure no water force
Can i get a manual for this not syre i have all the parts grandpa passed and trying to hook up
www.pressurewashersdirect.com/manuals/CH%20electric%20manual_2.p..
www.ppe-pressure-washer-parts.com/task-force-power-washer-parts
Jul 02, 2014 | Task Force 2000 PSI Electric Pressure...
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    Weak Pressure. I have the power washer running for a few minutes, then I go to pull the trigger on the wand and I only get about 1-2 seconds of full force pressure. The machine is still running (not as...
    Check for a clog.
    take the hose off the washer pump and start it. if you have good water pressure then you may have something on the hose or the wand. I had a lizard in mine that caused that problem before.
    Sep 11, 2013 | Karcher Garden
    Why does my washer start with a forcful stream and then cut doyn to minimum flow ?
    Check for kinked or clogged water supply hoses(s). Be sure to make sure that if there is a screen-like filter in the supply hoses or at the inlet on the wash machine, that it is clear.
    Shut the water supply off. Start the washer to fill on warm wash / rinse to relieve the water pressure in the hose. Shut off the washer. Unscrew the hose connection from the washer and direct both hoses into the washer tub (or other container). Turn the water supply on. Both hoses should discharge water evenly and forcefully, then shut the water off. If the flow was uneven, slow or poor - clear obstructions in / or replace the hose(s). Next, inspect the water inlet on the washer. Clear any obstructions, dirt, etc. Reconnect the hoses and try again. If flow is still lacking, there may be obstructions in water lines or valves INSIDE the machine.
    I hope this helps - please rate my reply. Thanks.
    May 06, 2011 | Craftsman Garden
    Power washer starts, water to washer on but no water pressure come out the hose
    this with the engine running? If so there eigther is a restriction in the main water feed or the pump is damaged or possibly needs to be rebuilt. Did you know you can never start the mechine with the water hooked up and on full and you should trigger the gun to force the air from the water pump before you ever start the engine. Is it a mi-t-m pump or a cat pump. The mi-t-m pumps have a problem with the plastic cages that hold the valves braking and getting stuck between the valve and the valve seat if you take the caps off the pump you can pull the peice out and the mechine will work again. The cat pumps have cremic pistion and if over heater need to be rebuilt but is a vastly better pump and if maintained wil last 25 to 30 years under heavy use
    Dec 07, 2010 | Briggs & Stratton Power Products 1539...
    I have a Generac power washer with briggs and stratten 4.5 Horse. I bought it 7 years ago and stored it. I started for the first time today, it started on the first pull and runs great, but doesn't pump...
    I hope you did have it connected to a water line. I'm also assuming the pressure washer function is working ok. Some times the sypon tubing gets clogged from cleaners drying up and building up in tubing and passageway. Does your gun have a cleaning on/off function sometimes by twisting handle? If you have an extra hose, try forcing some water in the tubing while trying to apply solution. If all else fails, clean all solution passageways.
    Oct 02, 2010 | Briggs & Stratton Power Products 1539...
    Have a 11hp power washer pump not sucking water, how do i fix ?
    Hey there...
    Is the washer a direct drive or belt drive unit? If it is a direct drive ( the pump bolts directly to the engine) then the pump needs to be force fed the water, either by city pressure or a transfer pump. If it is belt driven, the lower rpm's should pull water, so more detail would be needed...
    Feb 01, 2010 | Honda 8 HP Engine
    No pressure
    force feed the pump with water it sounds like its sucking air rather than water if no leaks check the 6 valves regards
    Jan 06, 2010 | Briggs & Stratton Prosumer 20324 Gas...
    I have a honda 3200 psi power sprayer that is loosing power, is their something that I can do to fix it.
    is the machine coupled up to mains water or are you make the machine **** from a water tub.
    if you are makeing the machine **** , then dont try force feeding with water and looking for a water leak or drip even from pump or connectors.
    you might find the machine works great off mains water pressure, if so check the valves
    Jul 04, 2009 | Honda Garden
    Garden Logo
    128 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
