I have no files on this anymore its in great shape. Worked fine. Once memory was full I deleted all files erased etc followed all instructions. Now all is says is memory full. Can't get rid of it. DO I have to buy a new one? Im reading reviews the same thing has happened on newer models. Is there a hard reset> Help!
SOURCE: Recorder says "PLEASE DOWNLOAD FILES," but there are no files to download
The DS-2 has a format option in the menu under submenu. After you choose start you will see a progress bar and it should return to full record time. Use on a MAC seems to cause the reduced record time more often than on a PC.
SOURCE: "Memory Full" message flashes, even though all files are deleted
Use the reformat option in the menu to completely erase the memory.
SOURCE: WS-110 memory full but no files
well, i resolved this myself by going to the sub-menu, and formatting
the recorder to its original state. thankfully, i backed up the files
on my computer first, so i didn't lose any data, although i did have to
go in and re-set all my preferences on the recorder.
lesson: don't MOVE files from recorder to computer. copy them instead,
and do the actual erasing from the physical recorder itself.
i don't know if this was the most elegant solution, but at least it did get my recorder up and running again. i'd love to hear if there is a better resolution out there.
SOURCE: Sony ICD-UX70/UX80 digital recorder...memory full problem
If you press and hold down the "menu" button scroll down to the FORMAT selection and press enter. This will reformat the device.
I had the same problem - I think it arose after disconnecting the IC Recorder when it became unresponsive with the computer.
Make sure you transfer all your files first to a computer or back up source.
