SOURCE: canon mp210 will not load paper this is a brand
E3 is paper jam.Make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.
SOURCE: Tonar empty error for xerox phaser 3100 MFP pritner
You have to reset your printer through a hardware module which is permanent resetter. www.nakshatraworld.com 09713862555
SOURCE: WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A
I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
friend ans my qust clear
