Question about Acer Aspire 4315 Notebook
Hi my acer aspire 4315 laptop comes up with a stop error screen just after the windows loading screen what could be the problem. thanks calum
Restore to factory default
Unlike other laptops, Acer notebook/laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer Aspire 4315 to factory setting.
Step 1: Before starting your Acer Aspire 4315 laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer one to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer Aspire 4315 is reset to factory settings.
Tips: You can also create a backup copy of your notebook data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Aspire 4315 Notebook/Laptops/Desktop, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Jul 26, 2010 | Acer Aspire 4315 Notebook
My acer aspire 4315 hangs during shutdown. windows XP OS
This happens when there is a process still trying to work in the back end.
Try to disable most of the applications which get opened by default when windows starts.
Click on start/run/ and type msconfig. Once the window comes up click on start up tab and disable all.
Now try to reboot the system.
Also hope there is no usb device connected at the time of shut down. This would also make xp hang.
Thanks
Mar 01, 2010 | Acer Aspire 4315 Notebook
Hi i had windows 7 loaded to my laptop acer 4315 and all my start up acer programs are gone how do i reload... thank you
You will need to manually reload them from the various disks they came on, After a reformat (I assume it was done) all programmes are lost until you reload them.
Dec 03, 2009 | Acer Aspire 4315 Notebook
I need to reset my aspire 4315 series back to factory settings as it's not running properly, I've lost my hand book and can't remember what to do, could you possibly tell me what buttons to press when to...
First plug in the Notebook to a power socket with your adapter. Power on the Notebook and you will see the Acer splash screen. Immediately prell ALT and keep tapping F10 at the same time. It will take you to a screen where you will see "windows is loading files" or "starting acer recovery" it will ask you, how do you want to restore?" choose the option "restore to factory default" and click continue. It will go through the restore process and within 15 - 20 minutes it should finish the process. Your Notebook will be back to factory default settings and once again you can see the OOBE.
Hope you find this solution helpful.
We appreciate your comments and feedbacks, Please do not forget to leave your comments and ratings.
Thank you for choosing Fixya.
Nov 15, 2009 | Acer Aspire 4315 Notebook
White screen
hi thanks for using fixya!
I suggest that you shoud bring your laptop to a service center to check exactly the errors are. This is the best option for now.
Best Regards!
Apr 19, 2009 | Acer Aspire 4315 Notebook
Windows xp on acer aspire 4315 cannot shutdown normally
ARE YOU SAYING YOU SHUT DOWN WITH THE POWER BUTTON.GO TO START RUN AND SHUTDOWN OR RESTART THERE.RICHARDM69
Dec 05, 2008 | Acer Aspire 4315 Notebook
Acer Aspire 4315-2004 Notebook
hi. sir..
please istall ur aperating system once again and try it.. it may be helpful.. thank u sir.. for any assist i am there .
Sep 07, 2008 | Acer Aspire 4315 Notebook
How to get password from hdd password error code acer aspire 4315
Is the error message coming before bios starts to load XP from harddisk, or after?
If it is coming after XP starts then it may be driver issue.
If it is coming before XP, then it may be a question of incorrect bios for the hardware in your laptop.
Jul 27, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 4315 Notebook Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
