Question about Grilling
Not enough gas through buners
Vidalia grill model 628. Grill cooks well for about 30 minutes then flame goes out. I love this grill which is essentially an outdoor convection z oven/smoker/grill. I am a Grass Fed Beef gourmet, and this grill makes it all possible. I have replaced the grill's burners, but problem persists. I believe the problem is in the propane valve or the control handles. Please help.
  • 57 Answers
It may be the regulator not sure but a easy fix
Posted on Aug 27, 2009
I just replaced and old worn out built in Turbo with a new model. Both are propane versions. After installing the new model works fine but does not generate enough heat. With all four burners on high...
If you are using a 20Lb LP Gas Tank, rather than hard piped to the grill or you're using Natural Ga, here in may lie the problem. If it is Natural Gas, was the grill converted or ordered for Natural Gas? If not, that's why it' not heating well.
If you're using a 20Lb grill tank, do the following:
1. Turn the Propane Tank Valve OFF and disconnect the hose from the tank.
2.Wait 5 minutes and reconnect the hose to the tank. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
3. Once the valve is fully open, light the burner farthest from the tank first and turn the control knob to HIGH. Does the flame height look correct for being on HIGH? If so, light the remaining burners the same way, Do all the flame hieghts look correct? If co, close the lid and allow the grill to preheat for at least 20 minutes. Did the grill thermometer go higher that 200 degrees F. If so, you solved the problem. Always remember to turn the tank valve ON very, very slowly.
If that did not solve the problem, the thermometer may be incorrect/faulty. I had this happen myself, with a new grill. To test it, invest $5.00 in an Oven Thermometer, like you use in a regular oven, It sits on the oven shelf. But, in this case it will sit on the center of the grill's cooking grates.
Light the grill and preheat it for 20 minutes. Loo k at the grill thermometer and then lift the hood and look at the oven thermometer. The oven thermometer may be as much as 200 degrees higher. That's because it's actually reading the temperature at cooking level, not up in the air, where the grill thermometer is.
I never replaced my grill thermometer. I continue to use the inexpensive oven thermometer, because it's giving me the actual temperature, at the level I'm grilling at. And I, do a lot of grilling.
Hope this helped you troubleshoot and solve the problem. Pleas let me know and Happy Grilling.
Jun 24, 2011 | Barbeques Galore Turbo Elite 4-Burner with...
Cannot get high enough flame to cook - used to work beautifully and love the grill - all of a sudden not good flame
Either your burners need cleaning and/or the grill's regulator is locked up or the tank is low on gas.. This occurred when you either changed the tank or turned the tank valve ON. It happens very frequently. To solve the regulator problem, due the following:
Turn the gas tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. Reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow)). Once the valve is fully open, turn the burner ON. light it and turn the flame to the highest setting. Did the flame height return to normal? If so, you solved the problem. Remember to always turn the tank valve ON very, very slowly.
If the above didn't solve the problem and you've thoroughly cleaned the burner and the venturi valve, then you'll need to replace the grill hose/regulator assembly. You can purchase one at any home center or hardware store that sells gas grills and accessories. Take you old one with you for comparison purposes.
Hope this helps you to further troubleshoot and solve the problem. Happy Grilling!!
Apr 26, 2011 | Weber Q Grill
My weber genesis silver starts up, but doesn't get hot enough to cook the food. Seems like not enough flame out of either front or back burners. I tried Outting in a full propane tank, but that didn't...
Try these steps in order.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Sep 06, 2010 | Weber Genesis Silver B Grill
Grill lights but flame is low and goes out if control is moved from high. Burner tube is clean, spider screen is clean, and I have a full tank of LP. Grill is Q series about 1 year old and has been working...
Hello. Are you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
1. Turn the burners on for one full minute and then off.
2. Next, remove the regulator and the hose from the tank.
3. Then reconnect the tank to the regulator and hose.
4. And very slowly open the tank.
5. Last step is to fire up the burners and start cooking with you new hot flame.
The problem began the first time you opened the valve on the tank too quickly. In the future, always turn the tank valve on s-l-o-w-l-y to prevent this problem.. Joe
Mar 22, 2010 | Weber Q Grill
Gas grill caught fire
The anwer is not the one you want before Labor day cook-outs. Since the unit is under recall, go the manufacture's site, or any site specified in the recall notices, and follow the directions, to get replacement parts for all damaged parts from the fire, as well as the original defective parts. Hopefully you can take the unit in for exchange for a fully assembled one. Be polite but firm in wanting the units assembled gratis.
Aug 31, 2009 | Uniflame FG2204C Grill
Charmglow gas grill is not generating as much heat as it used to
potatoes should take about 30 minutes. if your grill is not hot enough un hook the tank and hook it back up again as you have a safety valve partially closed
Jun 07, 2009 | Brinkmann Charmglow 810-7400-S Propane...
Gas grill lights but doesn't get very hot
I had this same problem especially when the tank on my 5 burner 2 year-old Kenmore was about half full. The solution above fixed it. I was used to opening the gas fully, turning one burner to high and clicking the button. If I would have read the front of the grill I would have seen that this was incorrect. I turned off the grill completely, unhooked the regulator and reconnected it. With one burner on high I began clicking the button BEFORE I turned on the gas. I slowly turned the gas on one quarter turn and it lit up full flame. I slowly turned the gas another quarter turn and lit the second burner. I slowly opened the gas all the way and lit the third and so on. That did the trick!
Mar 10, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Kenmore gas grill 141-16228
I would love to know the answer myself, I can't figure it out now that I have the grill half taken apart.
Jan 14, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Grilling Logo
261 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
