Question about Sanyo DS27910 27" TV
Channel A channel got deleted by mistake. How do I get it back. When I press resetit scans through all the channels but wont put the deleted one back. Can you help me
  • 298 Answers
Press menu key
highlight channel scan memory
press vol+ to highlight number entry area
enter channel you want to enter eg. C16
or if above 100 press and hold the 1 key until C1--pops up
change deleted to added by pressing vol+
Posted on Nov 16, 2007
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
How do I reset my kenwood TK-3212L
Press the key programmed as Scan Delete/Add to add or
remove each channel to or from the scan sequence.
• The channel add indicator ( ) will appear on the
display when the selected channel is added to the scan
Press and hold the key programmed as Scan Delete/Add to
add or remove each zone to or from the scan sequence.
• The zone add indicator ( ) will appear on the display
Oct 14, 2014 | Radio Communications
My scanner was woking fine untill i hit a button by mistake and now it wont scan through the channels ... i dont know what button i pushed!
To remove the lockout from a channel, manually select the channel and press L/OUT so L disappears.try this the channels could be locked
Jan 22, 2011 | Uniden BC898T Base Scanner
There is no local channel,cable only international..i lost my manual,
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
The NOAA weather frequencies have constant broadcasts, so your scanner "locks" onto them. The only ways to prevent this are to either delete the weather frequency or lock it out. To delete, just program the frequency "0.0" (zero point zero) into the channel. To lock it out, press the L/O key while on the weather freq.
Bill B
Aug 06, 2010 | Radio Shack Pro-84 Handheld Scanner
I need to get my tv back on channel 75 but it skips from 71 up to 99. How do I channel search?
I have a Sylvania TV. However, the solution should be roughly the same. There are several reasons for your issue. The TV provider could have moved the channel or taken it off of its roster. Or the cannel could have been deleted from your TV set-up by mistake. Barring that, you could do either a manual or automated channel scan. Make sure to save the channels.
Jul 28, 2009 | Televison & Video
HT 1000 Set Scan mode
First, your radio must have one of the side buttons programmed to be scan on/off. You will need to experiment while one or more of the channels is active and press the side button to see if it puts you in scan mode.
If it is, most likely a short press turns on scan, and a long press would be nuisance channel delete. This feature will temporarily eliminate a channel out of your scan list for the time your have your radio turned on. Once you shut the unit off and turn it back on, it would return to the original setting.
The only way to have a button programmed for scan/nuisance channel delete, is to us Motorola propritary software available to dealers and certain businesses and governement agencies. If you are needing to turn on scan or change a scan list, you would need to have the radio reprogrammed. This typically will cost between $25 and $40 at more dealerships.
Oct 03, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Raidoshack 1000 channel scanner
The frequencies probably aren't the same, so you're gonna have to do a little research, but hope this helps.
  1. Turn the scanner off and then back on.
  2. The first thing we'll do is clear all of the frequencies in the bank you'll use to listen to Gwinnett County.
  3. Press the black F button, then press 0, then press the F button again, then press CL, and then press the 1 button.
  4. Enter 000 and then press PGM to enter programming mode starting at channel 0. On the display the P on the left of the first line of the display says you're in programming mode, and the 000 indicates your looking at channel 0.
  5. Press the orange T button to enter trunking mode.
  6. Press the MODE button until Motorola is displayed on line 2 of the display.
  7. Press the PGM button again to begin entering frequencies. You'll enter 24 frequencies total. If you make a mistake while entering a frequency you can press the CL button to delete the last number entered. If you accidently press the PGM button twice while entering frequencies you can press the down arrow to back-up to the previous location.
  8. Enter the first frequency, 854.78750, then press ENT and then press PGM to go to the next channel.
  9. Repeat step #8 for the rest of the frequencies 854.81250, 854.83750, 855.31250, 855.48750, 855.76250, 855.78750, 855.81250, 856.81250, 856.83750, 856.91250, 857.81250, 857.83750, 857.91250, 858.78750, 858.81250, 866.13750, 866.21250, 866.38750, 867.33750, 867.38750, 867.96250, 868.11250, 868.13750, 868.48750.
  10. To double-check that you entered all of the frequencies correctly enter 0 and then the PGM button to go back to the first frequency entered.
  11. Press PGM to go through all 24 frequencies, if you see a mistake enter the correct frequency and then press ENT to save it, continue pressing PGM until you have verified all 24 frequencies.
  12. Next press 0 and then PGM to go back to the first frequency again.
  13. Press the MODE button until you see MO following the channel number on the first line of the display (P000 for example). After MO is displayed press PGM to go to the next frequency.
  14. Repeat step #13 for each of the 24 frequencies.
Mar 07, 2008 | Radio Shack Pro-97 Handheld Scanner
Concierge series 25" wont stay on channel 3
If Im not mistaking , some of Zeniths TV sets cannot be unplugged or disconnected from the wall. It will delete the memory and I guess the default channel is Channel 52.. I didnt know you disconnect the set in the ? you asked before. To stop this simply plug the set into an always on wall receptical and turn on the cable then the TV set. your going to need to do this order of operations as I know Zeniths will detune and you wont get any color sometimes if you turn on the TV then the cable. Sorry nothing you can do short of getting another set. Good Luck
Jul 30, 2006 | Zenith C27A24T 27" TV
Sanyo DS27910 27" TV Logo
223 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
