Turn off tv power
I use the rogers box to turn off the tv with he rogers box in cbl mode but the tv goes into stanby.Is it upposed to do this and will it cause damage in standby all the time.37 in dxlcd37-09-02 .How can i turn it off with box. Thank you. Tom.
  • 304 Answers
First your tv will always go into "Standby" when it receives a "Power off" signal. Made that way. Second, It is never a good thing to have your tv power plugged into a "Switched" outlet on a Cable ot Sat box or some other Component. The tv should be always be plugged into the wall outlet or through a very good surge protector.
Posted on Jul 17, 2009
Sharp LC-42SD1E NO PICTURE
it must be a problem with the router box what is your tv servace what is your provider (dish charter tds etc.)
Jun 04, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tip
How to Program your Innovage Jumbo Remote Control
Would you like to program your Innovage Jumbo Universal Remote to your TV, DVD, VCR, Satellite or Cable Box?
Have you tried the Auto Search function?
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly untilthe TV turns off. The LED will blink once each time you press theON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
When searching for a TV code, the remote will try all the codes it knows for every TV brand it know. To search for a DVD or CBL code, make sure you substitute the DVD or CBL button for the TV button in the directions above, because it doesn't attempt DVD codes while in TV mode.
When programming the Innovage Jumbo Remote control for cable or satellite services such as DirectTV or Comcast, or other digital TV and service providers, make sure to auto-search through both CBL and SAT code sets to find one that will control your set top box.
I hope that helps.
on Jan 02, 2010 | Innovage Jumbo Remote Control
When tv goes on stanby it starts scanning
The firmware corrupted. Contact the authorized service centre.
Apr 09, 2014 | Televison & Video
Emerson lc370em2 will not turn on just flickers
Hello Mike, seems you have a problem with your power-supply board....*or check if the tv switched back into standby mode..if tv switched back to stanby mode .....please check your A/V <Main proccessing Board...
Hoping to inform you correctly I remain,
Yours friendly.
Blessings.
Gladmar.
Mar 15, 2014 | Emerson Televison & Video
I need all the remote codes for a synergy5 remote so that i can control my zenith t.v.
Hi
Setup code for Synergy-5 remote control with Zenith TV are:
047 048 049 050 051
391 405 406 434
Proceedings.
[1] Turn on all the electronic devices (TV, VCR, DVD, AUDIO) you want to program the remote to operate
[2] Press [OK], then [MUTE] together until the power / mode buttons illuminate in slow-rotation (i.e. CBL ?
TV ? VCR ? DVD? AUDIO ? CBL...).
[3] (a) To program your TV, locate the 3-digit code for your brand in the TV Setup Code list and enter it on the
keypad of the remote control. Entry of the correct code will cause your TV to turn off. If multiple codes
are listed for your brand, you may have to try several different codes until your TV turns off.
(b) As soon as you have entered a 3-digit code that turns your TV off, press [MUTE].
(1) If the TV turns back on, press [OK] to lock in the code. The power / mode buttons will blink 3-
times and go out.
Or
(2) If the TV does not turn back on, enter a different 3-digit setup code until your TV turns back on.
Then press [OK] to lock in the code. The power / mode buttons will blink 3-times and go out.
OK.
Jul 23, 2011 | Zenith Televison & Video
Tv is in stanby mode. when i turn on power it seems like it wants to start but nothing comes up on screen. stanby light is blinking
The problem is in the main board of the tv, it is either a power supply issue or a high voltage problem. In order to isolate you will need a tv tech to check the set out and cost involved.
Jan 07, 2011 | Sony FD Trinitron WEGA KV-34HS510 34" TV
TV will not turn on.
Good Evening,
Sounds like the Startup Circuit is not kicking in. Looks like a repair shop issue. You can call first and get an estimate should that be the problem.
Hope this helps and thank you for using FixYa!
Mar 26, 2009 | Televison & Video
I have a Rogers HD cable box and want to control my Soyo HDTV with it. I look in the Rogers manual but could not locate the device code. Can you tell me what it might be?
first you have to know witch remote you have there is a 3 button witch has vcr tv and cbl at the top that one there press tv and select at the same time untill the light flashes 3 times release then enter 9-9-1 the pres the tv button untill the tv turns off if you have the newest 5 button remote you will press tv release press and hold setup untill light flash's 3 times then enter 9-9-1 light will flash once entered then press ch+ sevral times untill your tv turns off once tv turns off stop and press setup and that will lock the code inplace i hope that helps
Nov 24, 2008 | Soyo DYLT032D 32 in. LCD Television
Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
Nov 13, 2008 | Pioneer PDP-5070HD 50 in. Plasma...
No sound coming from reciever from tv
Make sure connections are going-audio out from tv to d-tv/cbl in on back of reciever. Then turn on tv and turn reciever input to d-tv/cbl and make sure the input mode is on auto. Hope this helps you.
Jan 24, 2007 | Yamaha HTR-5440 Receiver
Televison & Video Logo
Top Televison & Video Experts
