Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Paper got jammed in our HP L7780and after it was unjammed we now have grinding gears on start up and it still says we have jammed paper
    Habit-Forming:
  • 121 Answers
The jam might still be inside but you need to be sure all papers are all cleard,ckeck tray 1,where it picks papers carefully,and check the fuser assembly to be sure it not broken and faulty.
Posted on Jul 13, 2009
HP LJ 4L paper jam light flashes indicating a peper jam after printer makes a grinding noise. What can be the problem?
You may be right about the worn gear as a factor but I used to have a LJ 4 and whenever it indicated a paper jam it was always right. In some cases, the jam was a tiny scrap of paper deep inside. It took a flashlight and examination of every bit of the paper path to find it
Nov 02, 2012 | HP Black Toner for LJ4L & 4P
Jam paper
Hi
Please follow the below link and it might help you getting started again with the printer.
http://www.manualsprinter.com/manuals/hp/HP_LaserJet_Pro_M1217nfw.pdf
Oct 06, 2012 | HEWLETT PACKARD - LASER JETS Laserjet Pro...
How to unjam paper jam?
There are a number of things that can cause a carriage jam.
To prevent it from recurring, one should keep in mind a number of things.
Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside.
Also the paper being used should be as per the manufacturer's recommendations.
Turn off the printer when removing bits of paper.
If there is a broken gear, do not repair it yourself.
Call an expert technician to mend it. get more help for HP Carriage Jam .
Aug 04, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
HP Officejet 6310 All in One - small paper being faxed is jammed. How do I unjam the paper?
Lift the scanner lid, then lift the black part of the fax - pull up hard for it to lift. Unjam the paper either still on top or gently lift the inner section and retrieve your jammed paper. Then put everything back together and you're right to go again.
Oct 08, 2009 | HP Officejet 6310 All-In-One InkJet...
My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Feb 26, 2009 | HP Office Equipment & Supplies
Paper jam hp 5510
Look in the rear of the machine for an access door.
Jan 04, 2009 | HP Officejet 5510 All-In-One Thermal...
Hp 4100 paper is jammed between rollers the back panel should come off? and then how do I get fuser out to unjam paper
Hi Jacque,
I gather the paper has got into the fuser and cannot get into the output bin. Few things...
1. Clean output rollers. Are rollers moving?
2. Check gears on the fuser unit. Any broken or worn gears?
3. Check default paper size setting in printer, paper size setting on tray, paper size setting in printer driver and document page.
4. Leave the back door open. Does the printer still jams? If it does, see it could be paper pick up problem. Use different trays or the manual feed. Also the fuser unit could be the problem.
5. All else fails, replace the output assembly.
Rgds
S88
Dec 18, 2008 | HP LaserJet 4100 Printer
Paper jam
Look at this link for information on paper jams on the HP LJ 1320:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=410622&prodTypeId=18972&prodSeriesId=410622&objectID=c00230694
Here is a general link to HP's support site for paper feeding issues:
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=110&prodSeriesId=410622&prodTypeId=18972&supportTaskId=12407
Mike
Nov 08, 2007 | HP LaserJet 1320n Printer
Paper Jam
locate at the back portion of your printer there is small rectangular like a door pull up and then get those paper that causes paper jam slowly see to it that there is no paper left....and start printing again if it does not worked then try to clean your paper rollers...
Oct 22, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
168 people viewed this question
Seeker5211
Seeker5211
