Question about Troy Bilt Tb70ss Gas Trimmer
Too Much String from my Troy Bilt
Put a new bump know and head on my 4cycle Troy and the I can get it to stop spinning out the line. I check the tech drawing in manual and all parts are there and in the proper orderl.
  • 134 Answers
The majority of the time excessive string feed is caused by one or a combination of one or more of the following:
String wound backwards. Seems simple enough, but happens to the best of us.
Missing or improper spring.
Lubrication ANYWHERE on the shaft or inside the bump head assembly. This item should be clean and dry..but never lubricated.
If you know the model number on your particular trimmer, that would assist in troubleshooting.
I hope this helps.
DROPNDEAL
Posted on Jul 19, 2009
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Why does the weed eater not trim even though it spins?
it is getting hot from friction because you cannot tighten it so the head spins but everytime it hits a wed it tries to stop spinniing because it is slipping from the bolt not tightened. fix the bolt hole with a tap and put in a new bolt
Jul 14, 2015 | Troy-Bilt Troy-Built Gas String Trimmer...
How do I change spark plug in troy bilt 4cycle leaf blower
Remove the plug wire boot from the plug and the use a 16 mm. socket to remove the plug. Check the gap on the new plug and install in reverse order.
Oct 14, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do I replace string trimmer string on 4cycle Troy bilt string ttrimmer
verify that you are using the proper diameter trimmer line, if you have the proper line, replace the head of the trimmer
Sep 14, 2014 | Troy Garden
Can not remove line reel, the knob just spins.
I'll send you a link to the operators manual. To change the cable, simply unscrew the bump feed knob anti-clockwise.
Jul 28, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Replace duel string trimmer line
Change the line on Troy Bilt 4cycle TB525EC weed eater
Oct 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I don't know how to load line into the Troy Bilt Speedlock head
cut to pieces of string about 8 ft long. run your line through the holes on the side of the head. you will see 2 smaller holes on the inside. put the string in those 2 holes and begin turning your head to install the string.
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Can not remove spool to replace string
If it's like my Ryobi, the alignment arrows are for feeding in string, not removing the spool. When aligned with the arrows, you should be able to insert two pieces of line into opposite sides of the housing. The ends of the line will come out of the spool next to a tiny hole. Put the end of each of the two lines into the holes, then pull the two lines from the outside. This will lock the ends of the line into the tiny holes in the housing. Now you can turn the housing by hand to wind the lines onto the spool. I think it will take about ten feet of line (on each side).
Alternatively, spin the bump stop out of the assembly. This holds the spool in, so when the bump stop is removed, the spool comes right out.
I hope this helps.
Jul 01, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
String will not feed when bumped
I've never had any luck with those stupid bump heads. Every time I would refill them, the string would get caught up. They bind up. I finally replaced the bump head with a string head that you place short pieces of string in. They're not perfect either. You have to pre-cut the string to about 9-12 inches in length, and just replace the piece when it's time.
Jun 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
403 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
