Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G runs heavy
My Kirby Ultimate G runs heavy since last month even after putting
the Drive switch on (it used to be really light in that mode before).
Is there something broken inside? Is that something easy to fix
or do I need to take it a professional?
    Problem Solver:
  • 5 Answers
Hi, I'm Jon IO used to sell these machines and I also own an Ultimate G, And sounds like to me it's a loose or broken transmission belt, I think you should have your local Kirby dealer take a look at it or even a good quality vacuum shop will be able to look at it.
Posted on Nov 26, 2007
How can i tell the year my kirby diamond ultimate g was built?
Look at the serial #. Disregard the first number. The next two represent the year, the next two the month, and the next two the day. The last three are the daily sequence.
Example: 5021203456, would be the 456th machine finished on Dec. 3, 2002.
Jul 26, 2011 | Kirby Ultimate G Bagged Upright Vacuum
No power from Kirby!!
Determine if the headlight works before anything else. If the light works but the motor won't you have power thru the vac and the problem is internal possibly motor brushes... or a loose wire on the inside connecting to the switch.
If the light goes out is likely a switch or cord problem. Switches on these vacs break more often than cords. What you see on top is the switch button, not the actually internal switch, however a switch does not normally fail while the vac is running, that sounds more like a loose connection or a bad cord.
So isolate the cord. Unplug it at both ends and plug lamp ( or test meter) into the cord into the cord and gently wiggle where the plug end meets the cord. If the lamp goes on and off the issue is the cord. You can buy a replacement specific to the Kirby series and plug it in yourself. If this s does not isolate the problem, take it to a service center. Kirby is very intricate inside.
Sep 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G wheels lock up when in drive...
Replace the transmission. The tranny that drives these Kirbys can give you problems.
May 16, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby attachments instructions
Ok, the hose goes on the front. The light should lift up then, the front emblem rotates. this releases the belt from drive shaft. Underneath where the light was, there will be a release lever, which will release the entire front end where the brushes are located.
Once removed, you will see the intake fan and bar beneath it. The hose hooks to this bar. Then to the left of intake, there is a safety switch. The end of the hose has an arm that will fit into this safety switch.
Once hose is in place, the release lever that loosened the brushes will now tighten the hose.
The bag stays in the same place. If you have the 2nd handle attachment, you can use that to replace the upright handle. The release button on back side of handle.
I own a G4 and used to sell the G6 which was right before the one you own. The G3 thru Ultimate G are work in the same manner just different colors.
Hope this was helpful.
Apr 22, 2008 | Kirby Ultimate G Bagged Upright Vacuum
they are pretty easy to use you cant really put it together the "wrong way" they wont fit :-)
Jan 26, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5
nuetral/drive, the g series has a power drive motor for the back wheels
May 13, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
87 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
