Question about Bosch HBL 745 Stainless Steel Electric Single Oven
Bosch HBN745AUC control panel broken and needs to be replaced. Any DIY advise appreciate, included the parts no. and cost information.
If you mean the glass in front of the display and touch panel is smashed, you can buy a new glass panel, about $200, part 239424 (for a stainless oven), see bosch parts link below. Probably the electronic touch sensor board underneath is fine, but its basically glued to the glass panel so will be a bit tricky to peel off and re-glue to the new one.
http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=HBL745AUC%2f02&ESHOPTYPE=S
Posted on Aug 22, 2009
Frigidaire remove control panel
Good Afternoon Evan - Regrettably, this is not a simple DIY job. Generally, qualified technicians often perform these complicated part replacements. Usually this type of information is not released to a consumer and very rare to find enough information to do it yourself. If I was in your position, I would personally suggest contacting a professional to accurately assist with the repair or installation of the part.
Jul 02, 2013 | Frigidaire FGET3045KF 30" Double Electric...
Kitchenaid superba failure codes e1,f2, and door is locked
Hi Bill:
The E1F2 error code indicates replacing the board. It is in the realm of possibilities that your new board is defective. If I were certain the board was good I would focus my efforts on tracking down an electrical fault.
The likely failure is the control panel; however it could be the control board.
Since you did replace the control board already, the problem is most likley a key pad that is sticking.
I added a portion of the technical data sheet in the image below. You will need an ohm meter to be able to check the key pad operation. I added the information needed in the image below. If the control panel tests OK, replace the control board, if it fails, replace the control panel.You may need a hands on tech to run these tests and diagnose and repair your oven. Or just buy the key pad controls. Check THIS LINK.
Here are the parts
Replacement parts for WHIRLPOOL KEBS208DSS8 ' AppliancePartsPros.com
Here is a manual and a tech sheet
https://secured.whirlpool.com/Servic...all%20Oven.pdf
http://www.servicematters.com/docs/w...%204451879.pdf
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | KitchenAid KEBC208 Electric Double Oven
I have a GE JTP70, The Plastic over control panel bubbled up.
Mine did the same thing...and believe me it even looks worse over time....look online it happened to a lot of people....GE won't do anything about it....it is a defect but they won't own up to it......They just want you to keep replacing the part, which cost a fortune. Mine oven cost over $1000 and I am stuck with a nasty looking piece of garbage in my brand new kitchen......can't afford to buy a new one.........I Will NEVER BUY ANOTHER GE PRODUCT AGAIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Feb 19, 2010 | GE JTP70 Electric Single Oven
Kenmore Pro: top oven element has one hot leg. Checking control pnl board found control L1 hot but wire to element not getting power thru some type of contol modual. Lower oven operating normal.New panel...
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 15, 2009 | Kenmore 42161 / 42169 Electric Single Oven
Kenmore oven Model 911.30169792 Control panel lights are on
Apr 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
We are replacing the control panel on our Whirlpool RBD305PDQ8. The code that comes up on the panel is E1 F2. What does that mean?
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Jan 25, 2009 | Whirlpool RBD305PD Electric Double Oven
How to remove the control panel on Whirlpool double oven Model RBD305PDS14
Remove the doors by turning toward you a little toggle apparatus located on each hinge. Locate a small screw on the lower inside edge of the left and right hand trim and then slide off the trim. Remove the lower trim then raise the upper trip and put the left end of the panel inside the top opening. This allows you access to the control panel. Test both the keypad part #8300440 and the control panel part #830219 to see which one needs to be replaced. Order the replacement part, plug it in, reverse the precess above and it should work like new..
Oct 02, 2008 | Whirlpool RBD305PDS Electric Double Oven
JKP56 and JTP56 Differences
Those are not full model numbers, but basically a JKP56 fits a 27 inch cabinet and a JTP56 fits a 30 inch cabinet, so obviously the key panel / control panel would be different. I looked up a couple ERC range controls, and they are also not compatible. Note: usually you will not need both of those parts. The most common of the two is the front panel. (common F1 error code) If this answers your question a "FixYa" rating would be appreciated. Thanks.
Sep 25, 2008 | GE Profile JTP56 Electric Double Oven
Bosch fan oven not working
This does not mean your element is broken. Although it could be. Call Bosch and ask them if the unit has a pressure switch (you will need the model number). Pressure switches are more common on Gas ovens, but it might have one. If the pressure switch is not being activated by the fan, that could be the problem. It could be a contactor, it could be your power switch. It could be a break in the wiring. Or it could be your thermostat, or it could be the element. Service companies usually charge you for the cost of traveling to your place and around here hourly rates from $65-125 per hour for labor. It could take up to two hours to find out what the cause (or causes of the problem are) depending on how thorough they are. There could be a return trip charge as well if they need to order parts. And the cost of parts as well. you could be looking at anywhere from $300 to $1200 dollars depending on how many components might be damaged and the cost of the parts. If you want to save some money in the future, always check your fan blade to make sure it is free of debris (especially tin foil) and make sure the motor on the back of the oven has some clearance from the wall so it can cool itself.
Jun 17, 2008 | Bosch Ovens
Bosch HBL 745 Stainless Steel Electric Single Oven Logo
982 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
