Garden Logo
S
Steve Shea Posted on Sep 09, 2015
Lawnmower starts but dies after a few minutes. Where would I get a manual for this lawnmower?
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Jun 09, 2009
SOURCE: lawnmower is spewing white smoke
white smoke means that there is water in the fuel air mixture during combustion. a bluish white smoke means oil is being burned during combustion. take another look and make sure which one it is. since all mowers ive seen are air cooled the only way water can be getting in the fuel air mixture is through the gas cap. check your gas tank and gas can for water. may be best to empty both and start over with fresh fuel
mickey813
mickey813
  • 472 Answers
  • Posted on Sep 30, 2009
SOURCE: Murray 22'' 6.0 hp gas lawnmower engine dies right after start up.
SOUNDS LIKE YOU NEED A FULE FLUSH AND CARB KIT
gtmerkley
George Merkley
  • 194 Answers
  • Posted on Oct 10, 2009
SOURCE: Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Anonymous
  • 95 Answers
  • Posted on Mar 14, 2010
SOURCE: My lawnmower won't start. WHen I turn the key it
Check battery cable for correct hook up. Red positive to starter and black to ground. If battery connected backward starter rotates in opposite direction and can burn up starter. If correct battery hook up check plastice gear on starter for wear.
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Sep 05, 2010
SOURCE: the lawnmower starts for a
Probably a fuel delivery issue. There is a brass bolt that holds the bowl to the carburetor on. It has an exterior washer, so don't lose. This bolt also is the main jet for the carburetor and can become clogged especially if old gas is allowed to evaporate in mower and no in-line fuel filter is used. Drain the fuel tank (or it will drain when you remove the bowl!). The bolt has very small holes on bottom and sides. Make sure they are clean and clear and the bolt is nice and cleaned up. Use no metal, and/or scraping on bolt. Reassemble (don't forget the carb body gasket) and engine should run if no other issues.
Please vote on this solution.
Lawnmower starts then dies
Let warm up if still does need new spark plug
Oct 26, 2019 • Toro Garden
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
How do i fix my lawnmower
what mower is it and what engine is on it. I would hazzard a guess that if it will start then die over and over then you have a dirty carb that will need removing,stripping and cleaning
Toro personal pace mower will not stay started?
If ir starts and runs for only a few seconds it's a dirty carb/bad gas. Drain the fuel system and use FRESH gas; change out your fuel supply monthly to avoid "phase separation" issues. If it runs for several minutes and then dies it is possibly a sticking valve. Do a compression check cold and after it stalls to confirm. Hope this helps
1helpful
Have a Briggs and Stratten 4.0hp Lawnmower that starts but sputters. What can I do to get it running smooth...What is the Spark Plug GAP?
How old is the fuel? Drain old fuel, use premium fuel and change spark plug and maybe air filter. I start mine in the Spring using quickstart. It also starts and dies a few times and eventually keep running. Winterizing the machine in the Fall prevents most starting problems in the Spring. If this does not solve the problem, see a mechanic.
1helpful
Yard pro estate series
No it does not. LoL
Jul 15, 2013 • Garden
Electric lawnmower battery won't hold a charge
charger for same does not show any lights..so should i assume the charger is not working?
Self propelled lawnmower starts and then stops after two minutes mowing lawn
clean the carburetor jets out thoroughly with carburetor cleaner and a strand of wire through all openings. this is a common problem with the engine dies a minute or so after it starts up
Top Garden Experts
Jay Finke
Jay Finke
john h
