Question about Panasonic FP-7735 Black and White Copier
Help My copier folds the paper and it always puts a blank line down the middle of the page
  • 69 Answers
Hi im jules_09,check the fuser unit paper are folded because the rubber roller is worn out then the black line is also cause by scratch or damage upper or hot roller in the fuser unit.if the hot roller or uuper roller is fine check the drum unit if the opc drum is damage or scratch then check also the drum cleaning blade or roller,blak line in copy indicate one or two part either in the fuser unit or drum unit is damage.
Posted on Nov 16, 2007
OFFENDING COMMAND: Kassia
well a model number of the copier and the finisher would help
Feb 11, 2014 | Konica Minolta bizhub Office Equipment &...
I always have a black line down the middle of the page when i scan. help
If there's a black line when scanning but not when printing, you need to clean the scan bed. Either the glass has something on it or check the paper path if you're using the ADF. A single ink spot either place will print a line down the whole length of your scan.
May 12, 2011 | HP Officejet 6500 Wireless All-in-One...
Cant remember if I fax with paper facing up or down into feeder?
Just look at the tray that you lay your document in to be faxed. It will have an impression in the tray that looks like a sheet of paper. This symbol will either show something that looks like lines of text on the page and if so then you put the page in face up. If it appears to be a blank sheet with one corner folded over then it is face down. I am telling you this in case you need to know at some point in the future you will always have that indicator to tell you. You can also use the machine to make a copy and put the document in both ways and what ever way results in a copy and not a blank page will tell you which way is right.
Good Luck and Thank You for using Fixya!
WheatlandServices
Oct 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Konica Monolta c550. ignores trifold
the fold function is only available when the option finisher fs-608 is installed . here is the steps to make a trifold on a fs-608.
1 open a one page document it can only be 8.5x11 in size.
2 click file then print and pick the konica c550 in the printer name box. click properties.
3 in the output method select print leave the paper tray on auto leave the paper size on same as original click original size to indicate 8.5x11click on the radio dial to indicate portrait under original orientation.
4under the layout tab leave the following fields blank-combination,rotate 180,skip blank pages,binding margin and image shifton the right side of the layout screen leave print type as one sided and binding direction on auto.
5 under the finish tab leave paper arrangement at its default= prioritize arranging papers.make sure there is a check mark in the fold box and select trifold in the drop down menu.
6 click ok and go to the c550 to retrieve the document
Nov 05, 2009 | Panasonic DP-C264 Copier
Do I load the original for faxing right side up or upside down? HP officejet v40
Look at the input tray it shows a symbol of an original.
If the lines on the symbol face you , then put the paper in face UP.
If the lines are on the folded corner of the symbol, then place the paper in face DOWN.
If you are still not sure, place the paper in face UP and press "COPY"
If it copies the page, then that is the correct orientation.
If thre copy is blank, repeat the copy test with the document face DOWN.
Sep 28, 2009 | HP Office Equipment & Supplies
When I am faxing do I put the paper print side up or down?
Most printers are different even from the same monufacturer. The easiest way to tell is look for the icon near the place where you load the fax. There is what appears to be a sheet of paper with a corner folded over. If the icon shows lines across the main part of the icon, and there are no lines on the part that is folded over, then the paper goes in the machine face up, or lines up. If there are no lines on the main part of the icon but there are lines on the part that is folded over, then it signifies the paper being loaded face down, or lines down.
Sep 12, 2009 | Canon L120 Fax Laser Printer
Faxing up or down
Look at the hopper. It will almost certainly have a little graphic on it to tell you which way up the document goes.
If it looks like a sheet of paper with lines of writing on, the paper goes in print side up.
If it looks like a sheet of paper with one corner folded over, and lines of writing visible only on the turned over corner, then it goes in print side down.
If you can't find the graphic, then experiment: Take a blank sheet of paper. Write "Up" on one side and "Down" on the other then stick it into the machine so the writing is telling the truth. Most fax machines have a copy mode - use this to see which side of the paper the machine reads (if you can't get it to copy, fax your page to somebody and get them to phone back to tell you which side of the page they've received).
A.
Jan 18, 2009 | Brother Office Equipment & Supplies
Minolta EP 2010 copier, top loading doesn't pull paper
Hello sir; try to made 2 copies one go through by adf another one just put on the glass,if one copyclean another not clean then clean up the glass, if both copy all lines then replace drum unit.
Jan 06, 2009 | Office Equipment & Supplies
Paper jam
take out all the paper from the loading tray, and press down on the inside of the tray 4 or 5 times, and put a sheet back in. There seems to be a physical irregularity with all 2300DL printers that causes this problem
Sep 19, 2008 | Konica Minolta magicolor 2300DL Laser...
Panasonic FP-7735 Black and White Copier Logo
122 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
