Question about Whirlpool Refrigerators
Water is leaking really badly underneath my Whirlpool refigerator.
    Champion:
  • 287 Answers
I had this problem. Check you water line leading to your ice maker. the plastic section of it running up into the freezer cracks and leaks. easy fix, replace the tubing if it's leaking.
Posted on Jul 16, 2009
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
My icemaker on my refigerator the water stopped running into it
usually there is a double coil relay one for the water one for the ice you will need to replace it even if one is bad .
Dec 26, 2014 | Whirlpool Refrigerators
Water leaking out from underneath
How to Fix a Leaking Dishwasher Hose. *. Whirlpool Dishwasher Connection ... the drain hose pushes water from the dishwasher without water buildup ...www.ehow.com/how_12089937_fix-whirlpool-dishwasher-leaks-underneath.html
hope this will help
Jan 31, 2012 | Whirlpool Dishwashers
Water leaks into the refigerator compartment. The refigerator is about 15-20 yrs old.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 23, 2011 | KitchenAid Refrigerators
Hi I have a Whirlpool Refigerator and it drips water from the frezzer into the refigerator thru the two opening up in the back middle opening from the frezzer to the refigerator. It does this off and on
sounds like the drain live from freezer to outside is clogged. the water isnt making it you the condensate pan but coming out in the refrigerator. try finding and cleaning the drain line.
Mar 02, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
My side by side refigerator ge model TPX21PRDA is leaking fron underneath when the water line is turned on to the ice maker.....why and how to fix it.
I have found pin hole's in plastic water line. Pull out from wall and get a flashlight to see. Turn water
back on to find leak.
Feb 01, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking periodically (1x per week) from bottom of refigerator. Water clean and spreads on the floor about 1 to 1.5 feet in diameter.
drain pan underneath needs to be emptied. it should slide out but you may want to check for screws or bolts.
Jan 31, 2011 | Electrolux Refrigerators
My Whirlpool Gold leaking water
the water pump is bad, call a repairman usually only 75 to 85 bucks depending on where you live
Mar 01, 2010 | Whirlpool Washing Machines
Three year old Whirlpool Refigerator (ED5FHEXNB), water leaks from bottom of refigerator when outdoor garden hose water is turned on. Only leaks when outdoor garden hose is turned on. Water filter, Brita...
Hello it sounds like you have a leaking water hose which you need to find. maybe check first where it connects into the back of the unit.. Otherwise the fridge has a blocked drain in the freezer. cheers
May 15, 2009 | Refrigerators
Very bad smell coming from dishwasher
Possibly a water leak underneath or a dead mouse behind the unit.
Mar 17, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Refrigerators Logo
132 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
