Question about Cyberguard SG530 (SG0064US) Firewall
I can get a computer on the LAN but not the WAN. All the other computers work fine but I just got a new one and am having this problem.
    Novelist:
  • 154 Answers
The WAN (Wide Area Network) port is used for access to the internet through the use of a DSL or Cable modem.
You can't connect a pc to the WAN port it must be connected to one of the LAN ports.
Posted on Jul 18, 2009
What does the LAN do on the modem
There are two halves to a router. The internet (WAN) side a local network (LAN) side.
The term WAN means Wide Area Network and generally refers to the internet.
The term LAN means Local Area Network. That would be for the computers that are in your office or home.
The LAN connects your computer to your printers or to other computers.
I hope that answers your question!
Jul 02, 2014 | NetGear WNDR3300 - RangeMax Dual Band...
I'm trying to install a new 628 router. The wizard won't work and I have no clue what else to do. I have connected the router as per the limited instructions in the quick set up guide but it's not...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Dec 04, 2010 | D-Link Computers & Internet
I am trying to install my netgear Universal Wifi Range Extender WN2000RPT. I have green lights for my connection to the router, the extender is on and it is connected to the main PC. But I only have...
For that you need to check WAN settings and also make sure local ip settings gateway should be your router ip address. Make sure WAN settings are fine connect internet cable to WAN port of router. Then check. You can configure router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 10, 2010 | NetGear Computers & Internet
My laptop doesn't have any connection this am. Can you tell me how many light should be on the router or blinking. I have a Dir-601
The router's POWER lamp should be on, and steady.
The WAN lamp should be on, but blinking when the router is sending/receiving from the Internet.
The LAN lamp should be on, but blinking when the computer is sending/receiving from the router.
Disconnect the cable from the LAN port.
Turn the router off.
Turn the router on, and watch the lamps -- they all should light up, briefly, and then the WAN lamp should blink for a short time, as the router obtains a new IP-address from your ISP.
Connect the cable to the LAN port, and watch the LAN lamp blink for a short time, as the computer obtains a new IP-address from the router.
Oct 24, 2010 | Computers & Internet
Got new router and new computer cant seem to be able to hook it up with the router up stairs and computer down stairs
Are you having a modem that connects to a router, then from that router to another router? Well, you can't have a router's WAN as another router's LAN. It just doesn't work that way, you will need a switch for that. Or you can connect all of the computers to one route.
If you are only using one router, then have you try pushing the reset button on the back of that router? Or maybe you need the LAN drivers for your computer? If they are brand new, you shouldn't experience any problems, so you should return it instead.
Mar 09, 2010 | Intellinet Active Networking Intellinet...
Belkin router Flashing 5 out of 7 lights constantly. Help?
can you replace any cables to and from this router? Also, is it possible to turn it off for 5 minutes and retry?
Jul 06, 2009 | Belkin (F5D5231-4) Router
Not able to configure and connect to internet using router
Try 192.168.0.0 which would be the default address to access your modem. This should allow you to go into the modem and adjust changes. I know on the bottom of my router there is an administrator default password that can e used to access the mainframe of the modem. Check out these features in there. I would start first by connecting via LAN again and then try to conntect to it via a WAN but again see if you can access the modem using the 192.168.0.0.
May 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Dual Router Configuration
Plug the second router into the lan not the wan and it will act as a switch instead of a router
Oct 02, 2008 | D-Link DGL-4100 Router (DGL4100)
Router
i asssume that you have connected the ethernet port of the modem to the wan port of the router. if that would be the case, yes you need to connect the computer to the lan port of the router to get internet access. that it if you want your computer to be directly connected to the router. but if you're planning to connect wirelessly, you just need to make sure that your router and computer have a wireless capability and your computer.
Jul 04, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Computers & Internet Logo
140 people viewed this question
Top Cyberguard Computers & Internet Experts
David Payne
David Payne
Are you a Cyberguard Computer and Internet Expert? Answer questions, earn points and help others
