Question about Maytag M7DH65B2A Dehumidifier
Hose connected to drain, but still leaks water on floor
  • 4 Answers
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Posted on Jul 24, 2009
  • 4 Answers
The main drain is clogged and water is backing up in the water tray. If the humidifer is not perfectly level it drains at the back of the tray and down the inside of the unit. I just took mine apart for the same reason. The filter does not do a very good job and the fins and tray were full of lint partially clogging the drain.
Posted on Sep 07, 2009
2 Suggested Answers
SOURCE: Drainage bypass to hose not working
I taped down the float in the container so that the unit would not shut off when the conainer filled up. The water now is going through the drainage bypass .
Posted on Jun 22, 2008
Why does water leak onto the floor instead of draining into the tank?
The hose connector should be capped or a hose connected and directed to a floor drain.
Apr 29, 2015 | Amana D930M 30 Pint Dehumidifier
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
I have a Royal Sovereign BHD 450 dehumidifier. I moved and I do not know how to install the hose into the unit. It looks like it goes into a place in the bottom of the unit. The online manuals I found do...
Yes, there should be a screw out plug for the drain hole on the lower left. If the plug is not in there, the you will have water all over the floor. Unless, you can find the drain cap for it. The auto drain hose connection is about 6" above the manual drain hole, I just mentioned. That is where the auto drain hose connect. It's held in place by a squeeze clamp, that goes on the hose before making the connection. But, keep in mind, with out the drain hole screw in plug, water will still spill onto the floor.
If you can't find it, try Appliance Factory Parts 1-800-955-7075. As they may can help you.
Hope this helped you and thanks for choosing FixYa
Aug 10, 2011 | Royal Sovereign BDH450 Dehumidifier
How do I install a hose so this humidifier drains automatically?
Look at the drain pan, it might have a garden hose connection that you might have to knock out, mine is not the same model but it may be similiar, and then run it to a floor drain or such. Good Luck
Jun 30, 2011 | Whirlpool AD50USS Dehumidifier
/my dehumidifier has a hose attachment on the back. how does that work?
The hose attachment is used in place of the water collection bucket, to drain the water directly into a floor drain or a sump pump holding tank. A garden hose is connected to the "hose attachment" and run to the floor drain or sump pump holding tank. However, it will not drain UP, only DOWN.
Hope this helped.
Mar 20, 2011 | Amana Dehumidifiers
How do I connect the hose? lost manual
If you asking about the drain hose. There's what looks like a hose hookup on the back of the unit, down near the floor. It's probably plastic and is threaded to accept a garden hose. You may have to carefully knock out the opening of the plastic connector, to allow the water to drain into the connected hose. The hose then should go to a floor drain or sump pump. Keep in mind, the water will not drain up.
Feb 08, 2011 | LG LHD65EBL Dehumidifier
I put a hose on my 50 pint drain and it still just fills the tank, what do I do? PS the hose is not plugged
Is there a actual hole in the tank where your hose connects? Is there a piece of dirt clogging the hole in the tank.
Water runs down hill ... if there is a hole in the tank for the water to get out and the hose is clear and it is going down hill ... it must drain. The entire length of the hose has to be flat or down hill and no kinks.
Let me know what you find please
a
Oct 02, 2009 | Frigidaire FDL50R1 Dehumidifier
DeLonghi dehumidifier hose by drain tray leaking
I think that I am having the same problem, but I'm not sure that this tube needs to be plugging into anything. However, my humidifier seems to be draining out of this tube rather than from the tray into the bucket.
Jul 14, 2009 | DeLonghi Dehumidifiers
Water tank still gets full when connected to floor drain
Check the fitting where you connect the drain hose to. It may have a plastic seal that must be cleared out in order to use the hose drain. The plastic seal can be easily punched out.
Jun 07, 2008 | Danby DDR600R Silhouette Dehumidifier
Problem with draining water through hose
I bought one of the FDL70S1 Frigidaire dehumidifiers today for my shop, and found that the $5 hose I bought to drain it through the floor wouldn't tighten down completely, allowing the hose to twist and wobble, a sure indication that it was not water tight. Simply adding a second washer, as described in another answer here, allowed me to tighten the hose sufficiently to produce a tight fit with no play between the hose and the dehumidifier. It hasn't leaked. I know it is a threads-per-inch issue, and I am stumped as to why Frigidaire would supply these units with a different thread pitch than the standard GHT (garden hose thread) 3/4" - 11.5 tpi. The threads on the unit appear to be 3/4 NPS - 14 tpi. Go figure!
Jun 03, 2008 | Frigidaire FDL25P1 Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
395 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
