Question about Microwave Ovens
Bravetti microwave parts
I'm trying to locate a service centre to order a touch pad board for a friends K5345B microwave.Can some forward a name I can mail order it?
Have you tried cleaning the circuit board, preferably with alcohol?
Posted on Jul 12, 2009
  • Dewey Smith
    Dewey Smith Mar 13, 2016
    Quit wasting our Tim if you can't answer the question.
On the touch pad numbers 3, 6, 7 and 0 dont work
sounds like the touch pad control has failed ... there is a touch pad on this unit and also a control board located behind units touch pad... you can gain access to this by unplugging unit and removing console that houses touch pad /clock assembly ... once removed the only test there really is to do would be with power off remove ribbon cable to touch pad and make sure clear of any dust /debri and reconnect there are 2 small holes in ribbon cable that are used when reconnected fir into small slots and firmly connect... if that doesnt fix i would recommend a new touch pad... not sure what area your located... there is a distributor for sharp in dallas ,texas called
global micro parts... reputable company that if you give them your model number they can assist you with the part.... good luck to you
Jan 27, 2011 | Sharp R305KS Microwave Oven
None of the keys work
the touch pad has a ribbon cable that connects to the control board poosible that the touch pad has failed or the control board itself.... most of the time the touch pad fixxes the problem... if you have power and all still try ordering the touch pad for the unit...
good luck to you
Jan 09, 2011 | Microwave Ovens
Bravetti platinum pro model K5345B convection working but microwave turning but not heating
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARRAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 05, 2011 | Microwave Ovens
BPL MICROWAVE BMO700T. tHE LIGHT IS ON DOOR CLOSES PROPERLY THE DISPLAY SHOWS SOME C_, SOMETIMES 00.00 BUT THE TOUCH PAD IS NOT WORKING. WOULD LIKE TO KNOW THE TEL.NO. OF AUTHORISED SERVICE CENTRE AT...
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 09, 2010 | Microwave Ovens
I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
Dec 23, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave shows F2 on display with controls non functional
HI. this is a code that represents a failed key pad or touch pad membrane board. replacing this failed touch pad will fix this issue. This touch pad board is separate from the actual control board.
Aug 13, 2009 | KitchenAid KHMS155L Microwave Oven
Hello. The touch panel does not work, only clock.
OK, you will need to replace the entire controller assembly(key pad). this assembly that is in your unit at this time is damaged and, replacing it with a new assembly, will restore normal key pad functions. You can order a new assembly by clicking the link below or, you can call for service if you are not interested in disassembling this unit. professional service techs are recommended.
CLICK TO ORDER YOUR NEEDED PART.
Jun 07, 2009 | LG LMV1630ST Microwave Oven
Microwave starts without being touched
I belive you have a short in the touch pad. This part may or may be able to replace.I need More info on the brand name.DFD
May 03, 2009 | Microwave Ovens
Whirlpool Microwave
Sounds like the mounting tabs have broken on the plastic control panel frame. You'll probably have to order both the control panel frame and the membrane keypad since they are attached. You can't peel your keypad off the frame and put it on the new frame. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Search for model number as MT9100SFB0 Another option if you prefer not to replace the control panel frame is to glue it in place, probably from the inside, but you need to be sure the mating surfaces are squeaky clean and dry.
Sep 08, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
Microwave Ovens Logo
129 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
