Question about LG LSC26905TT Side by Side Refrigerator
When I shut the refi door the freezer door opens just enought to defrost the freezer
    Champion:
  • 363 Answers
Clean all door seals with dry rag or towel. Also clean all contact points with refrigerator and freezer.
Posted on Jul 26, 2009
Amana side by side freezer not cooling enought
With so little information all I can say is check to see if the coils underneath the refrigerator or in back behind the cover are blocked with lint or the fan is running that draws air across these coils and cools the compressor is running. Check to see if there is frost building up in the freezer on the back panel. If so then you have a defrost issue. This could be caused from a bad defrost timer control, a bad defrost heater or defrost thermostat. also check to see if the freezer fan is blowing. There could be a bad thermostat that controls the cooling it may be shutting off too soon. Check the door gaskets around the freezer and fresh food sections. If they are torn you could be losing cool air and drawing in warm air. There are so many things that could cause a poor cooling condition. All is usually fixable but the worst case scenario is a weak compressor. lets hope this is not the case.
I hope this helps.
May 25, 2014 | Jenn-Air JCD2389G Side by Side...
Freezer is Frozen shut
Try unplugging the freezer and leave the door open for about 30 to 45 minutes. Don't forget the door is open and plug the freezer back in. Set a timer in the kitchen so you don't forget. Once you can open the drawers look inside the freezer sides to find the controller. Most models have turn dial inside.
Mar 07, 2012 | Siemens Freezers
NO FAN OPERATION INSIDE FRIDGE
Sometime the factory installs a fan delay / defrost termination switch and if the coils are not cold enought thhe fan wont come on. leave it on and running and keep the doors shut, the fan might still start. Hope this helps how about a rating
Oct 27, 2011 | Samsung Refrigerators
Freezer freezing up led says 110
controller or controller probes are bad. It is reading 110 degrees so it never shuts off. Other issue could be the controller is not keeping unit in defrost long enought to clear the evap. I would start there first,.
Jan 17, 2011 | Hoshizaki Freezer FH2AAC
Drain keep freezing up at entry point to the drain tube causing water to freeze from the drain top down to the bottom of the freezer. ( frozen waterfall!) Could the defrost heater be malfunctioning? i.e....
Not sure of your model number and manufacturer, but in some freezer there is a seperate drain heater that should stay on for the complete defrost time. (the defrost heater will shut off when the evap coil reaches a certain temp, and the rest of the defrost time only the drain heater is energized.) That would be the very first place that I would start. Hope this helps
Sep 20, 2009 | Freezers
Freezer door pops owner when refrigerator is closed
Try to raise the 2 front legs so the unit is slightly inclined - so that if you open a door 45 degrees and leave it, it will shut closed on its own. Also check for excessive moisture on the base where the gaskets come into contact with - perhaps your gaskets don't have a good grip and seal - and you may need to have those changed.
Aug 26, 2009 | Refrigerators
Not only will the fridge side not cool properly, now the door won't stay shut. Temp in fridge side stays 20 degrees warmewr than what panel says.what a pos.
Fridge problem- How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Door problem-The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Aug 22, 2009 | Refrigerators
Freezer door closing problem
to keep freezer door from popping open close main door more gently try extending front legs a little to help the door swing shut
Aug 04, 2009 | Refrigerators
Ice is forming at the bottom of the freezer and freezing the bottom draw shut. it doesn't appear to be leaking and the door shuts properly. it's supposed to be a frost free freezer....
Causes:
High humidity in the immediate area causing condensation to freeze at the door opening
A frozen defrost drain line not allowing water to drain off when the unit is in defrost
A bad door gasket causing an air leak
Some freezers have a heated perimeter to reduce condensation. If the stop working, moisture can accumulate arounf the door perimeter and freeze.
Leaving the door open too long or something obstructing the door
Mar 28, 2009 | Freezers
LG LSC26905TT Side by Side Refrigerator Logo
83 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
