Question about Saeco Nina Bar Espresso Machine
When brewwing the espresso it sprays out instead of flowing down. What's wrong?
  • 132 Answers
This action can be come from limescale contamination in spout of coffee and the m/c to descalling
or if it done nearly it can come from air gab in pump internal so it must be to discharge this air out 1st and the stream of water it will begood!
thanks
Posted on Jul 12, 2009
  • Oberexperte Jul 16, 2011
    I found that my Nina started praying after descaling and cleaning. Closer examination of the filter holder assembly showed that the support peg under the "perfect crema" coffee filter had been left out during assembly. Returning the support peg solved the spraying problem.
My Krups model 198 is about 10 years old and still works fine except the coffee isn't as flavorful and I noticed that the grounds have a hole down the center like they aren't getting f
Sounds like the water which should be sprayed over the grounds is dribbling out is a stream instead of a spray. Clean out the machine with an approved de tannin powder/solution and clean the spray head with something like a toothbrush. This should open up the screen holes and produce a shower effect again.
Dec 13, 2014 | Krups Coffee Makers & Espresso Machines
Brewer stops @ halfway thru airpot, will not let me adjust brew level
take front panel off and on timer board is a little switch. move it from on to 1 then hold breww switch till you hear 3 clicks
Mar 31, 2014 | Bunn CDBCF 15 Coffee Maker
Espresso sprays out side of filter
The head gasket needs to be replaced.
Jun 23, 2010 | Gaggia Classic Espresso Machine
Wasted espresso
Check the chamber under the valve, make sure that it is not filled with coffee grounds and water, also there is a small discharge chute under the chamber to the drain tray make sure that is clear.
Sep 12, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
The coffee has started spitting out, spraying
The group seal gasket needs to be replaced.
Jul 15, 2009 | Gaggia Baby Espresso Machine
Water flow has slowed down.
remove the spray head and clean it .also run the cleaning spring through the spray head tube this is what makes them slow down is minerals in the water.
Jul 02, 2009 | Bunn NHB Coffee Maker
Senseo coffeemaker 7810/15 is leaking water all over counter. Not sealing well?
Call senseo at 866-4-736-736 and describe the problem. it is the seaing mechanisim at the top brewwing portion that is loose, either you are not closing it right or the pressure is getting too high forthe seal.
if you have purchased or received it as a gift less than two years ago they will send a new one.
Jan 25, 2009 | Philips Senseo HD-7810 Coffee Maker
My Senseo coffeemaker 7810/15 leaks water out of the spigot all over the counter.
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem. it is the seaing mechanisim at the top brewwing portion that is loose, either you are not closing it right or the pressure is getting too high forthe seal.
if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Coffee spurting everywhere!
Unlike the other person offering a solution I have experienced this problem like you when making the first cup. I found that sending a blank shot of water through first does the trick before putting the coffee grounds on. Hope this helps.
Jun 09, 2008 | Gaggia Classic Espresso Machine
Saeco Nina Bar Espresso Machine Logo
164 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
