Question about Kenmore 24032\24036 Top Load Washer
Kenmore Series 80, Model 110.27812692, not filling with water
Everything else worked fine - agitated, spinned, drained the water. But I could wash only very small loads - not even the small load filled with plenty of water. I read these and many other articles. This one here on this website is super detailed - my kind of instructions! Thank you!
I still needed someone to show me how to open up the console - thought the whole cabinet needed to come off. Unplug the power cord first for safety. Remove both sides tabs at the top of the machine console where all the knobs are, remove two screws on each side and voila - the console flipped forward, up and over to show the knobs, electronics and tubes. To remove the knob, I had problems but with a little gentle rocking back and forth, it finally came up and out without breaking. I removed the pressure switch and installed the new one. closed the console (minus the side tabs), connected the washer. Nothing. not even agitation now. no water. just sound. I took the new pressure switch off, blew into the clear little tube and heard bubbles at the end inside my washer. Disconnected the power. Tried the old one. same old problem - but it agitated again. Re-installed the new pressure switch again, blew through the tube again. Re-connect the power. It is working just fine now - finished a small wash as a test and now I'm going wash my day away! Thanks so much for all the good information!! Yea!
jsrock516
  • 5911 Answers
SOURCE: My kenmore 80 series (top
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair. I hope this helps you. Let me know if you require further assistance.
Posted on Aug 13, 2008
  • 1028 Answers
SOURCE: Kenmore 80 Series Top Load Washer not agitating
if it will pump out ckd motor to gearcase coupling probably broke
Posted on Sep 03, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
aasc
  • 1606 Answers
SOURCE: Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Posted on Aug 02, 2009
  • 1937 Answers
SOURCE: I have a series 90
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11026912691/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Initial suggestion is a Lid Switch:
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Dec 14, 2010
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Kenmore Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washing machine
This is usally a timer problem that is shorted
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
244 people viewed this question
Sal De
fordexpert
Robert Rankin
