Getting the VCR to play through the old Philips TV
Where should I plug in the three colored cables on VCR OUT to the old Philips TV. I had to disconnect the VCR to install the HD box.
There are various series of three-holes lined up, four in the back and one on the side. Each would accept the cables from VCR OUT.
    Brigadier General:
  • 7,191 Answers
Looks as if you were using the AV cable to connect the VCR to TV. The three colored cables should be connected in the following order:
Yellow: From VCR Video out to TV Video In
Red : VCR Audio out (right) to TV audio in (right)
White: From VCR Audio out (left) to TV audio in (left)
Also check the color on the sockets on TV and VCR and match accordingly.
Hope this solves your problem. Thanks
Posted on Jul 12, 2009
Philips tv set 29PT6231/79R. Good picture and sound feeding through VCR machine. How do I get it to play video tapes? My previous tv played through channel 7.
I'd suggest connecting the VCR to one of the composite inputs on the set (Yellow, Red and White cable). Select that composite input, then tell the VCR to play. This will you give a slightly better quality picture than going through the tuner as you did on your old TV set.
May 02, 2011 | Philips Televison & Video
Can't hook vcr to tv
on the back of your VCR there will be a yellow colored port - most likely labeled "OUT" as well as possibly a white/red pair of ports.
The yellow is for a VIDEO hookup, the white and red are for AUDIO hookups.
These ports use what is called an RCA type connection.
Radio Shack, or just about any department store should be able to sell you an inexpensive set of RCA cables.
now on the back of the TV (possibly on the side) you will also have the yellow, white and red ports.
Hook one end of the RCA cable to the colored ports on the VCR, the other end of the cable to the colored ports on the TV.
last thing - the TV most likely has multiple inputs. there is probably a input button on the TVs remote, you need to press that button to cycle through the inputs until you get to the one the VCR is hooked up to.
its easiest to put a tape in the VCR and press play - when you get to the right input, you will see your tape...
good luck
Apr 05, 2010 | Dynex DX-L32-10A 32" LCD HDTV
How do I hook up my dish network and a wii console at the same time if I don't have the tv/ant cable I just have the red, yellow, and white cables?
Yellow is Video, Red & White are Audio, these wire color to color from unit to TV. Use these for the Wii, and the Dish, output will wire the same, if that is the ONLY way to output the signal... You can get "Splitter" boxes that allow a two to one, switchable input. Usually though, it's out with one, in with the other. most modern TV's have multiple ways of getting video into the set. Do you have any "other" Video/Audio inputs? Like, SVHS, Composite, Component? If so then you use one each and choose of the menu on the TV. Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Mar 03, 2010 | Televison & Video
Trying to install pc hp 7680 aprox. 3 yrs. old,to a newly purchased vizio 37in.1080 hdtv. and screen is coming up ( NOT SUPPORT). I contacted hp and they say they can help but, only for a fee ,because my...
Use these instruction to get you going. Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Feb 21, 2010 | Computers & Internet
Cable box-dvd/vcr- tv hookup problems
buy you one of those little boxes from like walmart,,that converts rca jacks to cable pugs ,,,there real cheap,,that will do it ,,in the electrinic isle,,
May 17, 2009 | Philips Magnavox DVD/VCR Dual Player
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Hook up
On the back, there are three ports that are color-coded and match the cables. Take the yellow cable and plug it into the yellow port. Do the same with the red and white. Take the other end of the cables and plug them into your TV or VCR. Most TVs and VCRs have ports for the cables on either the back or front, and are also color-coded. Plug the yellow cable into the yellow plug on your TV/VCR, and repeat for the red and white cables.
Oct 24, 2008 | Philips Magnavox MWD7006 DVD Player
DVP3340V/17 DVD/VCR
Well fbyrd95 goodluck. I have checked out the pages they offer for help. You will need to purchase a cable/satellite box to get the channels routed through the vcr. I received one of these for christmas. It is the sorriest excuse for a vcr/dvd combo I have ever seen. If this is bought as a dvd/vcr combo then I would assume that vcr means that it will record. I do not have the receipt or it would be returned. I will never purchase a philips product.
Jan 03, 2008 | Philips DVP3340V
TV seems to be "stuck" in VCR mode after power surge
your tv is playing dvd means your video &sound section is ok. as it is not playing cable means that there a problem in tuner section only. if cable connection &its socket is ok.
Sep 25, 2007 | Philips TS2768C 27" TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
