Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
I have a husky 26 gal compressor that will not refill until it has sat for a few minutes, it also wont develope any more than 75psi. it has not seen a lot of work since new in 05 i think. thanks for the help
    Brigadier General:
  • 4,088 Answers
Sounds like a defect in the bleeder valve that drains the line from compressor to tank after each pump cycle. The rings may also be stuck in the compressor. Try spraying WD-40 into the air intake of the compressor while running (remove the air cleaner material to do this). Have you changed the compressor oil? Things are likely gummed up from sitting so long without use. Have you drained water from the tank bottom?
Posted on Jul 12, 2009
  • 57 Answers
Do you drain the water from the tank if not try it
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    My husky 26 gal air compressor will not stop running
    Sounds like you have a faulty shut-off switch...
    Replace the shut-off switch with a new one...make sure it is of the same shut-off and turn on values
    Mar 30, 2013 | Air Tools & Compressors
    I need a capacitor(s) for my husky air compressor where can i get one
    I just bought a few my self , try "Drillspot" good service and prices.
    Don F
    Aug 12, 2011 | Craftsman 33 gal Air Compressor 6 hp...
    Compressor shuts off at 60 psi will not come back on until opsi
    If the pressure switch has been changed you will need to reset it if not ,then is the compressor trying to come back on but will not start untill it reaches 0 psi?
    Apr 25, 2010 | Campbell Hausfeld 26 Gallon Low Rider...
    I have a 5hp 26 gal upright cast iron.Moved lying on side
    clean fuel tank, and lines. just do a standard tune up. check every componet for wear or rust.
    Oct 26, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
    Coleman 8hp-26 gal will not develop more than 40
    could be piston rings gone check to see if you have crank case pressure a blown gasket can you feel air leaking out off gaskets valves sticking or not closing non return valve gone get back to me
    Sep 23, 2009 | Air Tools & Compressors
    Air compressor motor won't stay on?
    The pressure switch controls the motor on and off. Adjust the pressure switch up to increased the 'off' setting for higher pressure.
    Sep 17, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
    HUSKY 26 Gallon Shuts Down After <75PSI!?
    Possibly the pressure switch needs to be adjusted to reach a higher pressure. Trace the power cord into a box that also is piped into the pressure line from the compressor. If the pressure works itself back down again, use thread-locker fluid on the adjustment screw to hold it's setting.
    Sep 08, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
    Dent in air compressor tank
    was the tank creased? you can take it to a compressed gas refiller and ask them to pressure test the tank.
    May 25, 2009 | Air Tools & Compressors
    Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
    564 people viewed this question
    Top Campbell Hausfeld Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
