Question about Whirlpool GGQ8831L Gas Dryer
Dryer not heating up and is not turning off on timed section
Is it the thermal fuse?
    President:
  • 1,124 Answers
Could be.. Or could be the heating elliment...
Posted on Jul 12, 2009
Drying machine not working, the clothes always wet.
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Oct 03, 2014 | LG DLEX2550W 27" Front-Load Electric Dryer
Tip
Whirlpool or Kenmore Dryer Does Not Heat
Electric
First , check the circuit breaker to make sure they are on . Be sure to UNPLUG the dryer , while checking with an ohm meter . When checking WITH power , BEST to have another person available in case of emergency . I do know of 1 person killed while working on his dryer .
A dryer operating on 240 volts , sends 120 volts to the timer and 120 volts to the motor . In between these two , are the thermal cut-off , and the element ( this is the basic operation parts ) . The 120 volts from the motor , goes directly to the element if selected for heat . The timer circuit , sends the other 120 volts , thru the operating thermostats , then thermal fuse , then thermal cut-off , then high-limit thermostat , then to the element . Usually , not ALL the time , the thermal fuse ( number 1 ) is the problem . The heating element ( number 2 ) is usually the problem , if the thermal fuse is good .
If the thermostats , element , and thermal fuse check good with an ohm meter , remove 1 wire from the element and check with a meter , which side is NOT getting 120 volts . Trace the wire which will either go to the timer ( occasionally ) or to the motor ( extremely rare ) .
Gas
On a gas dryer , for no heat , or , heats for a short time then runs but no heat afterwords until cooled down , first check that the electronic igniter , glows red . If it does NOT glow red , then check power to the burner ( 2 wires ) . If no power , then the thermal fuse is bad . (On electric dryers , the thermal fuse keeps the dryer from starting . On gas dryers , it keeps the dryer from heating . The thermal fuse , is a 1" long , or oval , white piece , with 2 wires going to it ) . Also if it does not glow red , the igniter itself could be bad . Again , check with an ohm meter . If the igniter glows red and clicks off , but no gas , the sensor could be bad . This sensor , is mounted to the side of the burner box , and when the igniter gets hot enough to ignite the gas , the sensor opens , sending power to the coils , which open dispensing the gas to heat the dryer . To check the sensor , with the drum removed , start the dryer , and after the igniter gets red , pull one of the wires OFF the sensor , and the gas should ignite . Do this very carefully , as electricity WILL be in the wire pulled off . If the dryer heats for a short time then stops heating , the problem will be the burner coils . These coils will get warm from the electricity going thru them , and will " open " ( short ) internally , until they cool down . Then heat again for a short time , then open , until cooled .
Most of the time , either the thermal fuse ( 1 ) or the coils are bad ( 2 ) or the igniter is bad ( 3 ) .
........A thermal fuse is a white 1" long torpedo looking piece , or , a white oval shaped piece , with 2 wires going to it .
NOTE1 : The thermal fuse keeps an electric dryer from starting and keeps a gas dryer from heating .
NOTE2 : If your dryer heats but the clothes do not dry , then a venting problem is obvious , as a dryer either heats or doesn't heat . Pull the dryer out and disconnect the vent from the dryer . Dry a load of clothes and if/when they dry in the normal amount of time , this tells you either the vent hose is kinked , maybe pushed back too far , or , the outside vent is blocked , or , the vent in the wall is restricted to the outside .
Electric Dryers
NOTE3 : If your lint screen is on top of the dryer , the element , thermal fuse , and thermostats are behind the rear dryer panel ....If the lint screen is behind the dryer door , then the element , thermal fuse ( located behind the lint screen housing ( 2 screws ) , and thermostats , are located behind the lower front panel .
on Apr 17, 2010 | Dryers
My Whirlpool duet dryer isn't drying on automatic or timed settings. I replaced the ther-o-mister, but the dryer isn't heating up. How do you run a diagnostic on this dryer. Model GEW9250PWO
You should know that dryer has a thermal fuse located along exhaust Of heat... When You over load the machine the flow of air is not enough... Then thermal fuse is damaged ( open due security condition ) and the flame is turn off all the time... Just replace the thermal fuse. I hope this can help You. Sincerely
Jul 10, 2013 | Dryers
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    How do I know which thermal unit is the one that shuts the dryer off when the clothes are dry? one's called a cycling thermostat, another is called a fixed thermostat and the third is called thermal...
    Usually the Fixed Thermostat (also known as the High Limit Thermostat) and Thermal Cut-Out (TCO) are used in conjunction to regulate and protect the heating circuits.
    The Cycling Thermostat (also know as the Internal Bias) controls the amount of heat required/desired to dry your clothes.
    You need to remove the rear panel of the dryer to access the heating circuits on this model dryer. With the back panel removed, the heating circuits will be on the right hand side and the blower fan assembly is located on the left. The Hi-Limit Thermostat and TCO are located on the outside of the heater box with the Hi-Limit Thermostat mounted next to the heating element terminals and the TCO located at the opposite end of the heater box. The Cycling Thermostat is located on the blower fan housing next the Thermal Fuse. It will be the metallic round component, while the Termal Fuse will be a white plastic component.
    For better clarification, you can view an exploded view diagram of your appliance at pcappliancerepair.com. If you type in your model number, all the parts I've mentioned are listed under Section 3 (Bulkhead Parts). The components are listed as follows:
    Item 6 - TCO/Hi-Limit Thermostat Kit (both parts should be replaced at the same time).
    Item 15 - Hi-Limit Thermostat (sold separately)
    Item 23 - Thermal Fuse
    Item 24 - Cycling (Internal Bias) Thermostat
    If you are experiencing heating problems or longer dry times, please review the following link:
    http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
    Pay particular attention to the section that discusses dryer ventilation. The majority of dryer heat related problems and failures are attributed to poorly installed, clogged, or kinked dryer ventilation. If you haven't had the ducting checked in a while, now may be a good time to do so.
    If you have any questions, or require additional assistance, please let me know. I hope this helps you.
    Sep 10, 2009 | Roper REX4634KQ Electric Dryer
    My gas dryer turns o but wont heat up
    Hi, thanks for the inquiry.
    It's most likely a thermal fuse. Basically, the voltage has to go through the fuse
    Before it goes to the ignitor.
    If it's an electric, it's either the heating element or the thermal cut-off, most of the time.
    Either way, it should only cost you about $90 to repair.
    Best of luck :)
    Aug 30, 2009 | Dryers
    Maytag Atlantis MDE6200AYW will run, but no heat
    Check to make sure that you have the proper voltage running to the dryer first. Next you may have a problem with your heating element or with your thermal fuse. Get your dryer opened up so you can see your heating element. Run the dryer and if you see the heating element come on and then turn right back off again then you have a bad thermal fuse. If it doesn't come on at all though then the heating element is bad. Both parts can be picked up at your local appliance repair shop. Just make sure to unplug the dryer before replacing the part. If you have any other questions let me know and let me know if this was helpful for you. Good luck.
    Nov 22, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
    Gorenje Tumble Dryer WT 881 - how do I replace heating element fuse?
    I would start with house fuses or breakers, if breakers then turn breakers off then back on several times then try the dryer again. Then I would check the cord where it connects to the dryer. After that I would start checking elements, thermal overloads/cutoffs, etc. most dryers have several normally closed t'stat/ overloads and a thermal fuse. If the thermal fuse or cutoff is blown you also need to check your venting. these safety fuses are not resettable and are usually an indication that the vent may be clogged and/or obstructed.
    Nov 04, 2008 | Dryers
    Maytag washer/dryer lsg7806aae
    The easiest way i can tell you if it is an ignitor problem or a thermal fuse or something else is to turn the timer  to the timed section past 10-20 minutes then slowly turn the time back while the machine is running once you hit the last 5 minutes you should hear a click at the timer and at the gas valve. If you only hear a click at the  timer and not at the gas valve it is probably a thermal fuse and control thermastat. If you hear a loud click at the gas valve it could be a bad ignitor .If you see an orange glow but no heat or intermitant heat the coils on the gas valve may be at fault
    Oct 10, 2007 | Maytag LSE7806A Top Load Stacked...
    Whirlpool GGQ8831L Gas Dryer Logo
    123 people viewed this question
    Top Whirlpool Dryers Experts
    Tim Whalen
    Sal De
    Craig Butler
    Craig Butler
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
