Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
I have water (condensation?) leaking from under the freezer
My freezer i leaking water from underneath/or from the door of my Admiral 2227DEDB/18. I have seen the answer:
"Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel"
but would like to get some kind of manual before I begin to take the freezer apart. Can anyone help my on what panels to move and so on?
  • nikolaj596 Jul 17, 2009
    Hi
    Hope you have time to answer more detailed. I understand what the problem is but not how to fix it. I have looked at this http://www.pcappliancerepair.com/newfind... and searched for the GC2227DEDB but how do I fix it. Is it behind the freezer or do I need to remove the panel inside the freezer or is somewhere near the refrigerator? (sorry to ask, but I it is very difficult for me to take out the freezer/refrigerator)?
    Regards
    Nikolaj
  • Admiral Master
  • 4,654 Answers
I appoligize for not seeing your post sooner here are some links to pages that may be helpful, Let me know if you need more help as Fixya has a problem notifing me of anyones response to a solution , Thanks, Sea Breeze
appliancepartsse@yahoo.com
864-812-1887
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://appliancejunk.com/forums/index.php?topic=22.0
PART NUMBER AND MODEL SEARCH FEATURE
Please feel free to contact me the charge is free, Sea Breeze
Posted on Jul 16, 2009
  • 3 more comments
  • John Tripp
    John Tripp Jul 17, 2009
    OK, got the email thanks for asking. You will need some help on this one. The drain goes down to the bottom of the refrigerator and drains into a pan under the refrigerator. The heat from the compressor and the fan blow warm air over the defrost condensate pan to evaporate the water back into the air. If for some reason the pan is cracked or the pipe going to the pan misses the pan the water will end up on the floor.. If for some reason the drain line is blocked in one of its turns going to the condensate tray below the refrigerator it will leak into the freezer or the fresh food section depending on where the leak or blockage starts. This also could be a water leak at the water control valve for your ice maker and water dispenser. On the rear near floor where the water line connects to fridge....Sea Breeze
  • John Tripp
    I will try to find a manual. But some companies don't allow anyone but their service technicians. You can look over the breakdown of parts listed for your model. Maytag is the only company that will share that information with the customer. I can try to help you. Sea Breeze
  • John Tripp
    If the leak begins in freezer you will need to unplug refrigerator and remove the rear panel inside the back of the freezer and defrost the ice and let me know what you see. Sea Breeze
  • John Tripp
    This may not be very helpful but it shows the drain funnel and line. The end of the line should end up in or over the drain pain below. If drain line is blocked use warm water and a little clorox and pour in drain and use a wet and dry vacuum cleaner to pull out the blockage. Sea Breeze
  • John Tripp
    Here is a picture of the freezer compartment from appliance parts pros. And here is a link to a bigger photo.
    Part number 14 is the drain pan under the evaporator coils behind pane # 20 inside back of your freezer compartment.
    http://www.appliancepartspros.com/partse...
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
I have a" Admiral designer series model HMG24922" Refrigerator, And the freezer keeps leaking out water can anyone tell me how to fix it!??
if it is a self defrosting unit then check the operating times of the defroster
if the water is leaking out of the door then replace the door seal
check for a blocked outlet tube for the freezer section
Apr 08, 2015 | Admiral Refrigerators
My Admiral side by side has a leak from the bottom of my freezer.
check your door gasket for air leakage, it sounds like condensation.
Apr 01, 2014 | Admiral 26 cu. ft. Side-By-Side...
I have an admiral fridge freezer model number GS2126CEDW.water keeps leaking from the front of the freezer and a build up of frozen water has accumalated at the bottom of the freezer.A person has advised...
hello again,
Sorry to hear that the drain is clear and not the problem, some of the other things that cause that water are;
Freezer door gasket...is it curled up in the corners espicially on the hinged side so air is leaking in and condensating resulting in water
The tube that send water into the icemaker is partially frozen so when water enters the icemaker it's being sprayed and dripping to the bottom(if thats the case ice would probably be built up all over the freezer)
The door for the ice dispenser isn't fully closing and will cause condesation just like the door gasket would
Good luck,
GENE
Oct 12, 2011 | Admiral 26 cu. ft. Side-By-Side...
Our magic chef with the freezer door on the left (upright) has a leak from under the drainage tray at the bottom of the freezer. There is a black gasket under the tray and the water leaks out of there.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | Refrigerators
Kenmore 18 top freezer doesnt freeze completely. refigerator cools to 48 f .
possible causes: bad door seals or condensate drain plugged causing evaporator coils (in freezer) to ice up, condenser or evaporator fans not on, condenser coils dirty, compressor not working, or a freon leak. if the back wall of your freezer is frosty or super cold, the coils are iced up. remove the back wall and defrost it with a hair dryer. if the water doesn't drain, unclog the drain tube. check the door seals for gaps. replace if necessary. check the fan in the freezer and the fan in the back. both should come on when the compressor is on. if not, check the fuses on the main board. replace if needed. if all that is fine, and there is no frost, you have a slow leak or a bad compressor. call in a pro or get a new fridge.
Nov 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Why would i have a lot of condensation in my fridge and freezer?
there is air leaking in from outside the fridge. Probably through the door flap on freezer door or a bad seal around the edge. Or the door couldve been left open
Sep 17, 2009 | Admiral AAV7000A
Leaking water on the front corner of the freezer side. We have turned off the water to the icemaker and have turned off the icemaker. Still leaking, not fast, but each day I clean up a puddle.
That is from your defrost drain either being clogged with food, or covered with ice. Behind the back wall in the freezer is a drain that empties underneath the fridge. If that drain gets blocked or froze over then the water will dump into the floor of the freezer and out the door gasket. Look in your freezer floor for ice build up. If you don't see anything like that or if you think the water is coming from underneath the fridge, then it is your condensate pan underneath. They crack sometimes.
Sep 06, 2009 | Frigidaire Refrigerators
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
1,210 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
