Computer does not start
I have downloaded from HP RAM/ROM update installed it and then the computer was switched off accidentally and when I switched it back on it died on me...
  • 198 Answers
Not good.
OK, Tap F8 when the computer is starting up.
When you see a menu, choose "Last Known Good Configuration".
That may undo what you did.
If not, hit "Delete" when the computer is starting up to get into BIOS.
Look for "Halt On" and choose "No Errors".
Save and restart.
If still nothing, get into your BIOS again.
Look for "External Cache" and "Disable".
Restart and see if you can start up windows.
If you can, get into BIOS again and "Enable External Cache" as this will effect your system's performance.
If you still can't get into windows try Safe Mode by tapping F8 again.
Do a "Scan Disk" by clicking on computer, right clicking your C: drive and look under tools. If necessary, do a "Disk Defrag" after.
The second last step is a "System Recovery" which you should look up how to do for your computer, as HP is different from other computers etc.
The last step? Reinstall operating system.
Posted on Jul 13, 2009
Need drivers for a MATSHITA UJDA730 DVD/CDRW
are you sure it the drivers?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-82302.html
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-88634.html
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-82303.html
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-88638.html
here are 4 different model drivers
hope this helps you
Aug 30, 2011 | Panasonic UJDA730 CD-RW/DVD-ROM (Combo)...
Problem when downloading file says installer integrity check has failed. common causes include incomplete download and damaged media. cannot install files.
If you're reading the file from a CD-ROM, then either:
* the CD-ROM drive is reading incorrectly,
* the CD-ROM is scratched, and thus cannot be read 100% correctly,
* bad RAM in your computer, that "corrupts" the data being read from the disk into the RAM.
Replace the CD-ROM.
Replace the CD disk.
Download "MEMTEST86+", and run it, to test the RAM; replace, if necessary.
Mar 26, 2010 | Computers & Internet
Color printed pages are too light.
  • Troubleshooting Setup and Install If your device is not recognized:
    • Verify that your cable is USB 2.0 high-speed compliant.
    • Ensure that your cable is connected correctly. Remove the USB cable, look at the end of the cable, and then match it to the pattern on the USB port. Make sure that it is not upside down. Insert one end of the USB cable completely into the USB port on the HP device and the other end into the back of the computer.
    • Check that the peripheral is turned on. Peripherals will not be recognized if the power is off.
    • Ensure that your USB cable is no more than 15 feet or 5 meters in length.
    • Check that the USB port is enabled. Some computers ship with disabled USB ports.
III. INSTALLATION INSTRUCTIONS When operating in a Windows environment, the CD-ROM setup or installation software detects the version of the operating system that you are running. The software is installed in the language that you have selected. For example, if you are running an English version of Windows and have the language preference set to Spanish, the installation utility will install the Spanish version of the printing software for the appropriate Windows version. INSTALLATION OPTIONS Two methods are available for installing printer drivers and software components for the printer.
  • Full (Recommended) . Installs everything that your device needs to work plus HP Solution Center:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL6 driver
    • HP Toolbox FX . Allows you to change some printer settings and contains documentation and self-help tools.
    • Screen Fonts . Printer-matching TrueType fonts help ensure WYSIWYG printing.
    • HP Color LaserJet 2605 series printer documentation. A list of documentation, which includes information about product operation, troubleshooting, warranty and specifications, supplies, and support.
    • HP Solution Center . Use HP Solution Center to gain access to product-specific software and on-screen help. By using HP Solution Center, you can access the HP Shopping Web site and update your HP software. If you have the HP Color LaserJet 2605dtn, you can also transfer images from a photo memory card. To start HP Solution Center, click Start, Programs, choose the HP program group, and then click HP Solution Center.
    • HP Photosmart Transfer . Software for transferring images from photo memory cards to your computer (HP Color LaserJet 2605dtn only).
    • HP Product Assistant . This software detects problems that occur with your HP products and can offer solutions to help you resolve those problems.
    • HP Software Tour . Use this for an overview of the software features.
    • HP Software Update . Use this software to check for software updates for your HP products.
  • Minimum . Installs everything that your device needs to work. The following is a list of available components:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL 6 driver.
INSTALLING SOFTWARE ON WINDOWS 2000 and XP Printing system installation from CD-ROM, Internet download
  1. Close all programs.
  2. Insert the CD-ROM.
  3. If the HP printing system installer program has not started after 30 seconds, complete steps 4 through 7.
  4. From the Start menu on the taskbar, select Run.
  5. Browse to the root directory for the CD-ROM drive.
  6. Select the SETUP.EXE file, click Open, and then click OK.
  7. Click Install.
  8. Follow the onscreen instructions.
USB Installation for Windows 98 Second Edition, Windows Me and Windows Server 2003 (Plug and Play Install)
  1. Turn on the printer and computer.
  2. Verify that the printer displays “Ready.�?
  3. Attach the USB cable to the printer and computer.
  4. When the Add New Hardware Wizard appears, click Next to install the USB Printing Support.
  5. In the following dialog, select option Search for the best driver for your device, and click Next.
  6. Make sure the HP Color LaserJet 2605 series CD-ROM is in the CD_ROM drive, select Specify a location, browse to your CD_ROM drive, and select the Drivers folder, then either Win98_Me( for Windows 98 and Windows Me) or Win2000_XP (for Windows Server 2003). For example, CD ROM drive:\Drivers\Operating System\Language. Choose OK, and then click Next.
  7. For Windows 98 SE, in the USB Printing Support dialog, you should see the path and file name. Click Next. For Windows Me and 2003 Server, this step may not apply.
  8. Once the files are copied, click Finish.
  9. Steps 4-9 will repeat to install the printer driver. File names will change. At step 9, you have the option to rename the printer. Click Finish. After files have installed, click Finish to close the dialog.
Network Installation for Windows 98 Second Edition, Windows Me, and Windows Server 2003
  1. Download HP's Install Network Printer Wizard.
  2. Run Install Network Printer Wizard and follow the on-screen instructions.
INSTALLING SOFTWARE ON MACINTOSH OS 10.2.X, 10.3X, and 10.4.X USB installation instructions
  1. Insert the CD-ROM.
  2. Run the installation utility.
  3. After the software installation is complete, attach the USB cable to the printer and the computer and then restart the computer.
  4. After the computer has restarted, open the Print Center or Printer Setup Utility to see if the printer name appears in the Printer List.
  5. If the printer name displays in the Printer List, the setup is complete. If the printer name does not display in the Printer List, go to the next step.
  6. Click the Add button, and then select USB from the drop-down list. 7. Select HP Color LaserJet 2605 and then click Add. The printer name displays in the Printer List. Setup is complete.
Jan 27, 2010 | HP LaserJet 2605DTN Color Printer
I had this problem for about 5 months my lg dvd rom dint read dvds . i installed ffirmware and tried to update it but there was erreor and now dvd drive doesnt even work. no green blinking light. when i...
This is the inherent risk in updating firmware to optical drives.
Buy a new drive, power down the PC, install it and reboot the PC. If it is and IDE drive, or a SATA for that matter, before you buy a new drive make sure to disconnect and reconnect both ends of the cable prior to replacing it, just to be sure it wasn't an accidentally dislodged cable causing the problem.
Dec 28, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
I need the drivers of SONY DVD ROM DDU 1615
You can install this software which will update your drivers automatically. It will first scan the drivers and then update your drivers if necessary.
http://download.uniblue.com/ub/dlib/li/driverscanner.exe
Do let me know if it does not work, I will let you know alternate way.
Kind Regards,
Khawar
Jul 05, 2009 | Computers & Internet
System doesn't boot
ref: HP Pavilion m8530f
Make sure you've updated the system BIOS on this computer. Goto HP website look up the computer, look for updates...download the BIOS update...resolves intermitten crashing. Since updating the BIOS I haven't had any more crashes or lock ups.
Aug 26, 2008 | HP Computers & Internet
Need to install printer again
Go to hp.com support, check updates and downloads, enter in your model number and download what you need.
Aug 14, 2008 | HP PSC 1610 All-In-One InkJet Printer
MEMORY UPGRADE
Sorry for the delay in my response.
Your computer will accept a maximum of 1 GB of memory. If both memory modules are the same brand and part number then it is possible that one of the sticks are bad.
Try each 512 MB memory stick in the first memory slot, without installing a second stick. This will troubleshoot to find out if one of the 512 memory sticks are bad. If both check out ok, then the problem is with the video adaptor.
Have you tried adjusting the refresh rate on the monitor as I described in my first response?
My final possible solution would be to upgrade the bios. Below is a link to the webpage for your computer system. You will find links for troubleshooting guides, driver and software downloads, product specifications, etc. If you click on driver downloads, then choose your operating system, you will be directed to a page that should provide the latest ROM (bios) update.
http://h10025.www1.hp.com/ewfrf/wc/product?product=93322&lc=en&cc=us&dlc=en&lang=en&cc=us
Jul 28, 2008 | Computers & Internet
HP zt1170 freezing, blue-screen, IRQL errors, etc
First of all, I recommend you to try using the Notebook with the RAM you had purchased...and remove the preinstalled ones.
Try using the 512 MB of RAM you had purchased by inserting it into the other slot if you receive Bluescreens with the RAM installed in one slot.
If you receive the same Bluescreen errors again and again, the issue can be with a damaged Hard Drive which might be having some bad sectors.
Additionally, IRQL not less or equal error message you receive indicates that few of the Device Drivers you had installed are incompatible.
Check them if you are downloading and installing the required drivers from any third party website other than from HP.
Hope this helps...
Jul 27, 2008 | HP Pavilion zt1170 Notebook
Matshita DVD-RAM UJ-85JS
Try download Everest! Is a software that make a list of all hardware in your computer, so you can view the manufacturer and in the site to do download the drivers.
Ps.: Uninstall all previous instalations that you make to this hardware.
Ps.: My english is bad!!!
Good Luck
Mar 18, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
David Payne
David Payne
