Question about Whirlpool Dishwashers
My dishwasher washed my load of dishes, but did not drain. So I unloaded it, and then hit the drain button. It wouldn't drain. If I hit any of the other buttons to rinse or wash the dishes it works, but it will not drain.
  • 51 Answers
There is a drain hose for your dishwasher that often gets clogged. Remove the drain hose and clean it out. reinstall the hose and your dishwasher will drain. The dishwasher should have a panel to remove and then comes out easily, just be careful not to pull it out too far. If this does not fixya then you may need to throw some parts at it, but hopefully not. Good luck
Posted on Jul 13, 2009
I have a Whirlpool Gold Quiet Partner III dishwasher. When I unload the "clean" dishes, there is some type of film or crud on the dishes. I have to hand wash them to get this off. It seems like a...
You need to check the drain system completely, look for plugged screens, pump impellers, valves and the drain hose. You need to witness a large volume of water flow during drain.
Sep 19, 2010 | Whirlpool Dishwashers
After the last wash I noticed the bottom of my dishwasher (Whirlpool quiet partner 2) was filled with water. After unloading the dishes I closed the dishwasher and pushed the Cancel/Drain button but the...
1.Check the drain filter for clogging.
2. Check the drain hose. Remove carefully to avoid water spill.
3. Check whether flows freely from the hose.
4. Check the drain valve if possible for you.
Sep 15, 2010 | Dishwashers
When we open dishwasher theres standing water in the drain area and it smells bad this is after washing aload dishs look clean but inside stinks
After you run a load of dishes put 1cup of CLR or vinegar (white) and run a quick wash.no dishes,after running dishes clean out spray arm and clean strainer,use a rinse agent like finish, and spray off dishes before loading.About 35yrs. ago I use to be a dishwasher as one of my first job's and if you did'nt spray the dishes and scrap them off before loading,the dishes would not come out clean,And after each shift the dish washer would be cleaned out.
Aug 04, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
After washing dishes it will not drain? My garbage disposal was broken, I just replaced it with a new one. We have done two or three loads of dishes since then, but now it's will not draining after the...
Check the air gap on top of the sink(silver dome next to the faucet). Clean out if plugged. I gather you did remove the plug from inside the disposal where the dishwasher drain connects.
Mar 24, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher didn't drain completely after final rinse.
Check the drain hose stub connection at the disposal for plugging. Lots of material flying around in there which could block the stub pipe. You might consider inserting a short section of drain pipe that has a built-in stub into the regular sink drain and plug the disposal stub. Also check the screen at the bottom of the lower spray arm assembly for plugging. Clean the screen in a mixture of hot water/detergent/white vinegar for an hour or so. That will remove hard water deposits from the screen as well as any food debris. The draining process is a timed event, so it depends on fairly rapid removal of the water. Hope some of this helps!
Mar 19, 2010 | Frigidaire 24 in. PLD2850 Built-in...
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher not draining
if you hold the start button in it should reset,possible cause could be a blockage in the pump or drain outlet under the sink where the drain hose connects.hope this helps.
Mar 05, 2008 | Dishwashers
Dishwashers Logo
55 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
